Good headphone amp and output for studio monitor
kurokiblack
Hi all.
I'm searching an audio interface that has a good headphone amp and a good output signal for studio monitors.
I don't care if its preamps sucks, cause I'm going to use the audio interface as an audio card.
Budget= max 300€
Can you reccomend something?
Thanks in advance.
Sorry for my English.
Welcome to ASR!
AFAIK, Topping Pro probably has the most powerful headphone amplifier among entry level audio interfaces. Here is Amir's review of the Topping Pro E2x2. (I think the currently preferred version is E2x2 OTG.)
Thanks for the reply.
As the review shows line out is not that good. I need both amp and line out for studio monitors. Any other reccomendation?
Do you actually need an interface with analog inputs? Is not super clear from your post.
Unfortunately not a lot of good options I'm aware of in your price range, the HP amps are usually under powered.
I have a MOTU M4 that I upgraded from MOTU M2, but I use a JDS Atom hpa with it.
If you don't need inputs there are lots of DACs that work well, I use a topping dx5 for my headphones, monitors (XLR) and 2 subs (RCA).
I wanted to buy a Dac/amp but I need to control the studio monitor volume so I decided to opt for an audio interface since I can control headphone and monitor with two separate knobs. I don't need good preamps but just good headphone amps and good output monitor quality.
I've found that (unless you want to use HP and monitors at the same time) you don't really need the two knobs. My Topping doesn't support output on HP and speaker outputs at the same time but I've never needed that.
But going for a cheaper DAC <$200 and adding a decent HPA like JDS Atom gets you 2 knobs within your budget with good quality all around.
Why do you need two separate volume knobs? My Topping DX5 II (and many other DAC/Amps) store the volume digitally and remember the settings for each output.
Which headphone do you use and at which volume level do you listen ?
With sensitive headphones at moderate sound level, a lot of audio interfaces can do the job well.
I had a small Audient interface 6/7 years ago and the sound with an AKG and an old Sennheiser was Ok, not earbleeding of course.
The haedphone outpul of my current Dac/hp amp Topping DX7 S is more powerful and a bit better, but that's not night and day in quality, believe me.
Except maybe with a few very difficult to drive headphones (which isn't the proper way to go for headphone design, IMO) nobody needs the max high power of a lot of headphones amplifiers on the market.
The race for increase in output power of headphone amps just went crazy and useless these last years. And dangerous for audition moreover.
I don't need two knobs but I need to control my studio monitor volume without going on the rear of them. I wanted to purchase a good Topping DX3 Pro+, but the knob controls only the headphone. There is no knob for the speakers. The same goes with JDS Labs Element.
I don't think this is correct, per the product page:
Looks like you can select a mode where the volume knob doesn't control the other outputs, but it's not a missing feature.
If that is true is a little inconvenient anayway. With an audio interface i can control the volume on an instant. I don't want to go through menus to adjust the volume.
I think in practice you would probably just keep the HP and LO outputs active all the time and adjust volume as needed. Or switch between LO and HP, you really just push the left/right buttons on the remote, I don't think it really seems like browsing menus. I've had a lot of interfaces over the years and still have some, I haven't found the Topping input selection / volume stuff to be burdensome at all.
If you still don't like the idea I can at least recommend the MOTU M2 + JDS Atom setup but the M2's HPA on its own is not great.
Thanks for the support. I really appreciate.
Anyway I read an article in which the author said there is no way to adjust the volume for the dac part but only for the headpone amplifier. The same goes of the JDS Labs Element. Once you go to the output line the knob doesn't work.
If the DAC/Amp is in DAC mode, then the output is fixed at it's maximum. If the DAC/Amp is in pre-amp mode then the volume control affects the output level.
For my DX5 II (which is in pre-amp mode), I run Balanced HP and Balanced Line Out exclusively (either one or the other). I switch between outputs by pressing the volume knob. The DX5 II remembers the volume for each output. It automatically sets the volume when I switch to an output. This works well.
Sorry for the noob question, what's the difference between DAC mode and pre-amp mode?
Right.
Audio interfacess allow instant separate volume control on different outputs, in general by machanical knobs, which is always the simpler way to do it, even in this age of electronic controls.
You should really consider buying a good audio interface for your specific need, with or without a separate headphone amp, depending on the quality of the one impmented on the interface and your own power and listening level requirements.
DAC mode is full volume output, while in pre-amp mode you control the output volume with that dial / knob.
This is the main reason why it's simpler for specific use (like wanted by Kurokiblack) to use a good interface or a good monitor controller rather than a hifi Dac/amp.
But, a contrario, if you want to listen to music with only one output at a time (sometimes headphone, sometimes speakers), a good DAC/ampi is best in absolute measured performance.
But anyway, even if an interface has generally less good measurements, many of these devices are good enough to be tranparent to listen in real use.
Let's do not be fooled by the race to super measured specs (which has become mainly a marketing race) as long as the measured specs are beyond the level of audibility of distorions or SNR.
And some high level interfaces like RME, Neumann or Merging, Lynx Audio, Prism Sound, the higher range of Audient, are all pretty good and near SOTA including spec wise.
As NTK suggested the Topping Professional E2x2 has great headphone amplifier and a good output quality signal. If you have any other reccomendation please tell me. Thanks.
@kurokiblack
If you follow Julian Krause I believe you have plenty of options to chose from; as he has reviewed tons of audio interfaces. Literally, from A to Z
