Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Fiio KA11 or Moondrop Dawn Pro - both are thumb-drive sized and measure clean on Android. Apple's dongle works but caps volume on some Androids. Skip extra features you won't use at this size.
The headphone/IEM model matters as much as the budget. For sensitive IEMs, a basic clean dongle is usually enough; harder-to-drive headphones may need more voltage. I’d also check Android compatibility and hardware volume control before choosing—balanced output isn’t necessary unless the headphones actually need the extra power.
Dawn Pro 2 (CS) probably the best entry-level $50 dac/amp dongle. There's better for higher price range.
Astell&Kern HC4 (AKM) can be found used for $100-150ish and sounds similar to the much more expensive and brand new HC5
AFUL Iceborne (CS) at $120ish brand new release also very good choice, sounds much fuller than Dawn Pro 2.
then iBasso dc-Elite (ROHM) and iBasso dc-Tonfa (R2R) are top-end. slightly bigger than thumb drive but still small
Hijacking: what is the best possible DAC for IEMs with DSD512 (HQplayer) at maximum $500 - $700 used ? max 1kg+ but ideally portable. Quloos MUB5 (R2R) gets accolades on head-fi but extremely expensive ($1500 new...) while many rank it similar to iBasso Elite (used $200-300)
The Qudelix 5k is superb. Well worth the £110 I paid for it. It drives all my headphones and earphones with ease and has a tremendous, highly configurable app. You can't go wrong! Mind you, although it is very small, it is thicker than a thumb drive. Here it is next to the old DAC/amp I used to use.
