My intuition is that if this dip is caused by cancellation, such an inverse filter may help narrowing it, thus making it less audible.Postive gain (idk what that dip is)
I could be wrong but the target curve is still flat. (See screenshot above). Engaging the Sound Character Profiler can pull down the high frequency (see below screenshot with HF tilt; 6kHz; -2db) using High Shelf 1. But I thought that was in 4.0?In the livestream, Genelec people said GLM 4.1 now makes the high frequency part less bright. Does that mean GLM has a different target response curve now?
The "target curve" remains the same. The goal in GLM has always been a flat frequency response of perceived-direct sound. Earlier versions of GLM achieved this in general, considering ITU-R BS.1116 compliant rooms.
Now, by for instance taking more a priori information about each monitor into account, the baseline frequency response has become more relevant in livelier rooms, and under ultra nearfield listening conditions.
GLM 4.1 is out now. Release notes here:
https://assets.ctfassets.net/4zjnzn...te_for_Mac_and_Windows_15-07-2021_-_FINAL.pdf
A lot of improvements:
-AutoCal 2 (Cloud only)
-Positive gain for some of the filters now possible
-Extended phase linearisation for The Ones
+more smaller things
I wonder the same thing. Hopefully Thomas can elaborate:"Users of the 8331A, 8341A, 8351B and 8361A models from ‘The Ones’ series of coaxial three-way point source monitors will welcome the new ability of GLM 4.1 to extend phase linearity right down to 100 Hz. With coaxial monitors, phase linearity is a valuable feature because it improves off-axis performance and stabilises UNF imaging too. GLM 4.1 accurately time aligns all the monitors in a room, across types, taking The Ones’ wide phase linearity setting into account."
What does it basically mean?
Pretty sure this concerns direct sound only, which does make sense since they now say they can better differentiate between direct and reflected sound. Basically, they just add some delay to frequencies higher than 100 Hz to compensate for natural and filter induced group delay.I wonder the same thing. Hopefully Thomas can elaborate:
- Will activating the phase linear mode improves the phase response of the filters and system response on steady state without calibration?
- Or does it imply that GLM takes the room into account and corrects the phase response post GLM and correct according to the room?
Extended linear phase mode equalises radiated delay from 100 Hz and up, with or without frequency response compensation. The "cost" is a few ms additional delay at 1 kHz.
The Ones make on-axis and off-axis sound naturally coherent, thereby helping an experienced listener differentiate between direct sound and reflections, and to exploit acoustic summation of multiple channels in the room, e.g. using head and body movement.
Extended linear phase mode further boosts such coherency, to an extent I have not experienced before in reproduction. Manipulating phase at the listener rather than at the origin, in general is not helpful from a natural/neutral perspective.
Thanks a lot Thomas. Then all I need to do is download GLM4.1 and activate “extended linear phase mode” without running GLM acoustic correction and then I be good to go right?
I look forward to it and report back the subjective differences I hear after the weekend.
Thanks. I don’t use GLM for calibration because I let the Trinnov Altitude-32 perform the room and multichannel time correction.I'm pretty sure you are prompted recalibrate when you change the setting, whether it is from OFF to ON or the other way around when you are editing an existing Group.
