D
Deleted member 16502
Guest
Thanks for clarifying.
Thanks for chiming in. May I ask a bit more in depth: can GLM (or will it be able to, for GLM 4) be used without being connected once to the Internet?
Once bitten, twice shy But, rest assured. GLM 4 will eventually have local calibration and functionality, including of course gain control ("volume").
It is currently in a beta phase where centralised calibration is an advantage, considering cross-platform consistency and diagnosing of potential errors. However, you may actually calibrate on the Genelec cloud server without being logged-in, should privacy be of concern.
The release version of GLM 4 will have both local and cloud cal options. No subscription or extra payment will be required, even for keeping GLM compliant with changing Windows and Mac operating systems.
With GLM 4, should I still try multipoint measurements or go back to single point.
Please download and install the release version of GLM 4. A lot of improvements and bug fixes have been done since the beta versions.Hello,
i tested extensively the current beta version which is working a lot better than the previous beta:
- it works in Mac even recent one: OS version Catalina and Big Sur, M1 chips are also working.
- W371 is supported
- I tested 7.2.6 configuration, various 5.1 and 2.1 configurations
not working:
- bass phase calibration
- random crashes
i am opening tickets with Genelec.
https://www.genelec.com/glm-software-download-page
What is the best way to manage multiple subwoofers in a stereo setup? I have 3 subs with a pair of 8341s. At the moment, I am phase-aligning one sub to each main, at setting the phase setting for the 3rd sub 180 degrees out of phase to the speaker it was phase-aligned with.
In terms of crossover and frequency response, the arrangement works really well. Where I'm still figuring things out is in terms of adjusting the levels for the subs. It seems that GLM matches the level of each sub relative to one of the subs (whose level is therefore 0). However, when playing back music, there is too much bass in a 3 sub setup compared to a 2 sub setup.
What is the best way of reducing the level of bass across the three subs whilst maintaining their relative levels to each other, freq response and phase settings?
What's the maximum listening distance that is OK with 8341A?Thanks - -9dB correction is where I ended up using my ears - listening for excess bass on songs I know, and judging whether or not the bass was balanced between the lt and rt side or not.
Sounds terrific btw
Isn't there a phase setting?Is there a setting to invert polarity in GLM for subs?
