Wunderphones
- Joined
- Feb 1, 2021
- Messages
- 119
- Likes
- 168
For the last several years, my stereo has been set up with an SMSL M500 running straight into a) a Purifi power amp driving my speakers via the XLR outs, and b) an SVS subwoofer via the RCAs.
The inputs of the SMSL are thusly occupied:
My TV has two audio outputs: Optical and ARC.
I ran the optical out from the TV to the M500's optical in, and experienced dropouts periodically--often enough to be unlistenable. I got a different cable, just to see if it made a difference. It didn't.
I don't know for sure that it's the TV's optical out that's the problem or the M500's optical in. But I think that's more likely.
So, I'm trying to figure out the best way to get audio from the TV's ARC output into my 2.1 system. I'm not committed to keeping the M500, if the best answer is just "buy a DAC with an (e)ARC input." But I wondered whether, for example, using an external converter to change the ARC output to optical, I might get around the TV's shoddy optical implementation.
- USB: Raspberry Pi streamer (mostly from Roon server over Ethernet, but some AirPlay)
- Coax: Digital DJ mixer
- Optical: Vacant
