German Maestro GMP 8.35 D Headphone Review
Rate this headphone:
    Votes: 95 61.7%
    Votes: 52 33.8%
    Votes: 6 3.9%
    Votes: 1 0.6%
Sometimes cell-foam or pillow stuffing or sheep-wool helps.
Sometimes some felt can help.
The problem is that the in certain cases one material works and other materials not so much.
It would be a matter of experimenting.
This is tedious work as it requires opening it up (screws), not breaking any wiring, changing materials (density), keeping a log, ensuring L and R is done the same, re-assemble ... rinse and repeat.
I find just listening is insufficient as the brain is easily fooled. Measuring is almost obligatory.
I see these headphones all the time in record stores here in Europe! I always thought they sounded awful, but I was never sure how much of that was just due to the headphones being in constant use and being completely neglected by the staff (they are often missing their earpads...)
.. and I have a couple of pairs from the brand (possibly a different model) I found out the back of a museum I was installing something at , conplete with their metal cable protection / wallmount - the kind you would have found on a public telephone booth .
They supply a lot of museums and things for robust, durable headphones for exhibits .. and record stores too by the sound of it !
I haven't been for a while, but maybe they're the kind you get at stores with those wall-mounted CD listening stations ? Music stores are few nd far between these days and I've not been to Rough Trade (where I last saw such a thing) for a couple of years ..
Yeah, so not a brand I would know for sound quality ...
Well, I applied some 1.5mm vibration-damping material and 2mm dense felt inside; the dip in the 4-5 kHz region (it was around 4600 Hz iirc) is gone, and I only hear distortion in the 4300–4500 Hz range—it’s definitely an improvement. I think I’ll stop here; the sound seems sufficiently balanced and clear to me
I decided to experiment a bit more and discovered the root of the problem: the groove-based joint. The headphone housing is made of a flexible, impact-resistant plastic, while the baffle is made of standard rigid plastic; instead of being secured with screws, the baffle is inserted into a dedicated groove. I applied some vibration-dampening material to the baffle itself and added a single layer of tape along its edge to make the fit within the groove tighter. The distortions disappeared completely
So, I applied some damping to the holes in the baffle using a thin wipe. On the driver itself, I removed the factory sticker from the center and replaced it with a 4mm piece of dense felt. The bass has improved significantly—there’s now a solid sub-bass response (40 Hz is clearly audible) with no perceptible distortion. The only remaining issues are a dip at around 4600 Hz, followed by a peak at approximately 5200 Hz but I already know how to fix that, only need to get protection for drivers to start new experiment
I decided to experiment with earpads and found a solution to the final issue—the peaks and the dip—in the form of NullMini hybrid earpads! They feature fabric on the inside, leather on the outside, and microfiber where they make contact with the head. The dip at 4–5 kHz has been almost completely smoothed out, as have the peaks at 5700 and 7300 Hz. They also sell similar earpads for Beyerdynamic headphones, so I’ll be ordering those in the future. It seems that all the issues with these headphones stem not from poor drivers, but from their specific tuning
Needs verification by measurements :)
Unfortunately, I don’t have a measurement rig; I can only evaluate the sound by listening to a tone generator and music
The overall sound signature is warm and analog. With the current leather earpads, the high frequencies suffer from the issues I mentioned earlier—plus, they are rolled off by several decibels. The midrange is free of any dips or peaks and is quite balanced, though the lower-midrange is almost certainly elevated. The bass is very dense and substantial, rich in harmonics; after I adjusted the damping of the central opening in the drivers, the response leveled out—likely sitting above the Harman target curve at least on mid-bass. Overall, I really enjoyed the sound; all instruments are clearly audible, and the drivers do not lose control, even when playing heavy music (Celldweller, Rammstein, Rob Zombie). I actually like this sound, I've EQed my HE400SE v2 before I sold them a few days ago to have very similar sound (+10dB mid-bass, +5dB low-mids and +5 dB on 2 kHz to compensate their dip here) and used it for a month or so, I find it rich and calming
I’ve considered building a DIY measurement rig, and if I actually get around to it, I’ll definitely take some measurements. That probably won’t happen for at least another six months, if not longer. I will also become the owner of a Sony MDR-MA900 in the coming days and can compare them head-to-head if you want
