Directly on the various websites where this adapter is offered, like the AliExpess link from post #1. And from the price stated in post #1 one might infer that it was the 16bit only model.Where did you find this information?
OK, looks I misread on that one, but I definitely saw the 16bit-only statement on some other website/ebay for (apparantly) the same range of adapters.The link from post #1 says 16-24bit though
In this manufacturer's case the specs do seem to match. There's a bunch of different models, all within the same price range, both class audio compliant and specced as requiring drivers for x - which I'm not interested in. Add a distributor or two and a reseller or two and whoooeee yes they might get them mixed up.IMO only checking the actual device capability (either usb configuration dump or the linux UAC driver debug info) can be trusted. Descriptions on Aliexpress are notoriously incorrect.
EDIT: Here: https://www.ebay.com/itm/256073194523
Thanks. What rates does the Format select offer? Very likely also 16bits are supported by the soundcard. Would OSX list all the card params somewhere?Here is the info from the version I got (BT/USB-C one).
Was just about to make the same point. In fact the headline description says 16 to 32 bit, which is not possible for AES.IMO only checking the actual device capability (either usb configuration dump or the linux UAC driver debug info) can be trusted. Descriptions on Aliexpress are notoriously incorrect.
$ system_profiler SPUSBDataType
B2+:
Product ID: 0x4007
Vendor ID: 0x0a12 (Cambridge Silicon Radio Ltd.)
Version: 19.70
Serial Number: ABCDEF0123456789
Speed: Up to 12 Mb/s
Manufacturer: QTIL
Location ID: 0x01110000 / 2
Current Available (mA): 500
Current Required (mA): 0
Extra Operating Current (mA): 0
Quloos QU02:
Product ID: 0x0a23
Vendor ID: 0x16d0
Version: 1.9b
Serial Number: <removed>
Speed: Up to 480 Mb/s
Manufacturer: Quloos
Location ID: 0x02100000 / 1
Those values do not look like real samplerates, more like an OSX list for UAC1/USB1 rates. E.g. it's rather unlikely that the device would natively support 8/16kHz.See the image in the prior post, which has the rates also.
They have it, just no effect on the output...not even when muted.The USB-host source (streamer, mac, iPad) has no volume control?
you shouldn't change the volume with PC, ipad iMac... it breaks everything
Because I am 10+ feet away and there is no reliable wireless way to control volume over GLM (their wireless remote sucks, nor can it work without direct line of sight) + needs to be accessible via the same 1 remote that is used for TV/Device control.Why? If the stream is PCM (i.e. audio, not AC3/DTS etc.), what difference does it make if the volume operation - dividing each sample value by a fixed number - is performed before or after sending the samples over USB?
Well, then maybe the device correctly reports its output terminal type as SPDIF (https://www.usb.org/sites/default/files/termt10.pdf table 2-6), and your sources have a "clever" rule that no volume is applied for SPDIF outputs. It may be configurable, e.g. for OSX google suggests to adjust application volume instead https://forums.macrumors.com/thread...-optical.2368768/?post=31704765#post-31704765They have it, just no effect on the output...not even when muted.
Sorry for not quoting, was replying to @patoulolBecause I am 10+ feet away and there is no reliable wireless way to control volume over GLM (their wireless remote sucks, nor can it work without direct line of sight) + needs to be accessible via the same 1 remote that is used for TV/Device control.
