Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,312
- Likes
- 11,201
8381 wins for sureUltimate Battle: 8361A + W371A vs 8381A
Thats very interesting. Weird how genelec states the 8361A is their most advanced monitor, and that the 1236A is their flagship monitor.That question was settled conclusively via a blind test over a year ago by Genelec. 8381A takes the cake.
BTW, according to some Genelec people, the 8381A doesn't sound like the "One," which is meritorious in my book.
W371A + "The Ones" is the baby version. It is the Beta test of the concept. The 8381A is the realization of all of Genelec's hopes and dreams!Ultimate Battle: 8361A + W371A vs 8381A
Makes sense. We are to the point where all of these monitors are top notch in how good they sound. Many of the differences is just directivity, SPL and how low the bass goesThey added a new layer to their marketing materials without updating the old layers. Opps...
Regardless, the 8381 is a free-standing main whose bass is controlled via cardioid technology. The 1236A (and the other big mains) are meant to be flush mounted, which offers a better bass control over cardioid. In summation, if a studio opts for a free-standing monitoring system, then 8381A is the solution. If it’s amenable to construct a front wall for flushing mounting then the other mains are the way to go.
FYI, when I inquire with Genelec which would sound better, a flush-mounted 1234A or fee-standing 8381A, the reply was “it depends on the room.”
I thought they said the 8381 was the same concept designed to have much higher loudness capability, didn't they?Ultimate Battle: 8361A + W371A vs 8381A
We can't compare different tools.Ultimate Battle: 8361A + W371A vs 8381A
One of the interesting things about the 8381 is that (at least I haven’t heard) about its bass steering modes.Not to mention, a pair of the 8361A + W371A is significantly cheaper than the 8381A. Potential buyers of the W371A probably already have bought The Ones.
Genelec would also have to consider the price when introducing a new concept or technology into its lineup. It would be hard to convince consumers if their strategy or narrative was to go straight to the 8381As without a cheaper and more approachable proof of concept.
I use the w371 in rear wall steering mode and that seems to suit me best.
With the 8381 it’s clearly capable of all those tricks i’m sure with that extra woofer especially. However there is no information on if those modes apply, if so are they user selectable and if not does the system just figure it out for you during calibration? Or is that what the white glove setup service will do for you?
Do the W371A's need space around them to work properly?
The manual says minimum 10cm space on all sides…
Not sure if the manual updated between them, but seeing that the sound grading has early reflections as a criteria:The manual indicates more than 10cm in front of the wall (for airflow), no comment on distance from side walls
Having just read the thread: yes, either if you listen loud enough or listen to material low enough in frequency, ie. movie sfx, you'll probably want additional subs.The W371 is not exactly a sub
So.... Do you still need to add subs to complement it and have enought bass?
Post in thread 'Genelec W371A + The Ones : My quest for the Grail is over'The W371 is not exactly a sub
www.audiosciencereview.com
Yeah i’m listening to my baby system these days the 8341 + 7360. With all the room treatment put into a smaller room. I’ve learned to be satisfied with lower levels. I’ll get the one 8361 and w371 repaired and bring it to this smaller room at some point.@srrxr71 your problem is solved?
