Thanks Mort. REL s3 . Only of moderate size. Listen 70, to 80 decibels. Classical to rock.don't uses DSP.
I was wondering small Genelec mains, and small Genelec subs?
Those are some very nice speakers and good bang for the buck. And a solid pair of 10" subs. Total cost new/used is $2k-$3k right?
I would think you will get the best Genelec bang for the buck with 2x 8320a ($1600 new) monitors and a single 7360a ($2700 new) 10" subwoofer with the GLM room correction kit ($400 new). It would be substantially better sounding for $4.7k. "The Ones" line is another $3-4k on top and delivers another marked improvement in clarity and power. My thought is for a single main listening place, a single Genelec sub should do it. If you need two to reduce room modes, that will add to the cost. Upgrading for more SPL can be done later but these together should easily produce 80db and more in a small room.
I'm a big fan of the Genelec used market. They are well manufactured and sturdy. That would bring it closer to $3-3.5k, but it's still a fair jump over the passives in cost.
How big will the difference be? I know the Ascend line a bit and I would say the difference will be quite noticeable. The biggest difference will be the DSP - more on that later. The tonality, FR, dispersion are all favorable on the Genelecs. The subs themselves are so solid, play loud and clear especially for their size. You can confidently cross them higher. They will probably have slightly lower max volume, but might not - depends on your amp.
DSP is recommended on this board
before new speakers most of the time. Genelec GLM isn't the cheapest source of DSP, but all the current sources are somewhat limited. PC works for some but is clunky. Wiim will get you part of the way, but I find it lackluster in general. REW is free and requires a lot of time to learn. MiniDSP is being hit by tariffs and AVRs are an odd purchase for a 2-channel music enthusiast. GLM is very good but on the expensive side given that you have to buy into the GLM system: the 8X30 series and 8X31 'ones' series.
I also like MiniDSP/DiracLive a lot. You could play with a DDRC-24 on the used market for $300 ($500 new?) and get a pretty good sense of what room correction/DSP will do. It's quite substantial and may satisfy for a while.
If you don't want Genelec DSP but want to try the Genelec sound, the 8030c or G Three (mostly the same) would be excellent with your existing subs. ($1.6k new) and deliver some better FR/tonality/dispersion which I think you would certainly hear, albeit subtle. I only recommend Genelec subs with the DSP (73X0 series) and they would be too expensive to buy and not employ the Genelec GLM system.
The DDRC-24 and 8030c would be a big upgrade together for about $2.1k new.
