Genelec Owners Lounge and Discussion
Currently my playback for my computer is USB to digital converter -> DAC -> preamp (or I have a decent TVC sitting around as well) ->
I have GLM and am interested in simplifying my setup, but I'm also running Fedora Linux as my main operating system. I can setup GLM's correction in Windows as I used to dual boot into it for LTSpice.
My question is how would I get the 9310B volume control to work with my Linux setup? Thanks.
9310B should just work since it's directly connected to the GLM hardware module. And the GLM hardware module will continue to work once setup. You don't need it connected to the computer if you want (can power it by any typical usb PD) and also don't need to have GLM software running.
I think you can also use a remote as volume control, as it's part of the Genelec workspace, but I will double check.
Yes, confirmed. https://www.genelec.com/9101b-wireless-volume-controller
Thanks @darth as well!
I think I am going to go for the wired as the person that reviewed the 9310B at ASR said it has hard stops, this will be useful for me to know that it's always at max attenuation when not in use.
I love my 9301b
A setup I saw on FB
Whelp, I am adding a 15" 7380a subwoofer. Got it all-in (w/tax and shipping) for $5.5k open box from Sweetwater. Soon I'll be 7.2 nearfield in a 10x10 room.
Providing an update on how the new Genelec 8351B's I recently purchased ended up measuring in my office after playing around with GLM.
Room Dimensions (L x W x H): 3.61 m x 3.50 m x 2.23 m (11.8 ft x 11.5 ft x 7.3 ft)
Room Volume: 28.2 m3 (995.0 ft3)
Calibrated: Yes (AutoCal 2)
Signal: Analog
Bass Management: Global, Full Band
Sound Character Profiler: None
System Delay: 0ms
Group Sensitivity: 0.0dB
Extended Phase Linearity: ON
RIGHT CH Freq Response
LEFT CH Freq Response
GLM Grade Report Summary
Both Monitors AccuSmoothed
Both Monitors 1 Octave Smoothing
Low Cutoff -6db point (Bass Extension) - I'm pretty impressed by these numbers for not having a Sub in the mix --yet
Is Genelec GLM login down for everyone else right now? My login doesn't work and Genelec website support also throws an error.
Many Finnish websites have been a bit flaky today, not sure where they are hosted, didn't check, but I wouldn't be surprised if it is some Russian bullshit going on. But could be a problem with some data center too.
Edit. It seems Amazon is more or less down where my.genelec.com is hosted. Cloud has made everything suck (and failures there affect "everything", and still money goes there).
I noticed Apple Music is not working either. :rolleyes:
GLM Autocal sweeps- Does anyone else find it odd or know why Genelec doesn't show the combined output of all driven channels in the Freq Resp charts when doing your measurements?
I couldn't find any explanation in any of their documentation as to why this is the case. Not sure how many real world use cases there are where someone is only using one speaker to explain the reason for this.
It seems the only way to gather these insights would be by saving the Autocal config to the speakers then using REW or similar to see the results of all channels driven.
As some of you already know, I was already quite familiar with the 8380s, having listened to them both in Paris at Audio-Technica and at Genelec in Japan, where I also had the opportunity to compare them with the flagship 8381s.
That said, I wasn't expecting this level of performance in a living room with absolutely no passive acoustic treatment. The listening position is about 2.5 meters away, which certainly helps, but the transparency and bass dynamics are simply outstanding.
GLM did an excellent job despite the room's asymmetry and the low-frequency room modes. I only made a few final adjustments using REW to validate and fine-tune the end result.
Amazing
My future end game setup
Congrats
