- Joined
- Jul 12, 2024
- Messages
- 2,863
- Likes
- 4,442
- Thread Starter
- #381
No unfortunately.Is there a chance to directly connect an appletv to the glm?
yeah that's my main reason, my MLP is too nearfield and I don't go full range anyway. I barely make use of the 8361a's. I prefer something a little smaller and what I need is more subbass. I keep hoping a 7380a falls out of the sky. You know it would survive it too.They still haven't listed what stand they are using for 8380. I wonder if it can be lowered or slightly tilted forward.
The thing I don't like about both setups is that if you are in a smaller room, the listening position might need to be increased in height if you really want that on axis.
83x1 can be tilted a bit down I guess but still that w371 raises it quite high
Same. I have an old dead link.
Lol I meant on their smaller monitors, like it is on the 6C for example
In case anyone was curious, I emailed Genelec support and they recommended the second option here.Have a noob setup question. I have a MiniDSP SHD feeding 2 8361As and a 7360. The MiniDSP has 4 outputs, and it appears that I have two setup options:
(1) wire all speakers to different outputs from the MiniDSP, or
(2) wire the sub using two outputs from the MiniDSP, then wire the 8361As using two pass-through outputs from the 7360.
Is there an actual difference between these two options?
Are you not using glm?In case anyone was curious, I emailed Genelec support and they recommended the second option here.
Are you suggesting that designing a speaker as such will always produce and overall superior outcome and Genelec needs to change?I've been wondering
Why doesn't Genelec add woofers on the sides or on the back like D&D or Buchardt?
The rear woofer(s) on Dutch & Dutch speakers do not contribute to them being cardioid.I think they assume their rectangular monitors will be baffle mounted which removes some of the need for the cardioid.
