- Joined
- Sep 19, 2019
- Messages
- 455
- Likes
- 304
I will be measuring my Genelecs and do room correction using GLM4 today. Until now my Genelec 8340 are corrected via GLM3. My Yamaha AVR RXV775 does something strange. When I set speakers to large and choose extra bass, I get more information into Genelec monitors when compared to setting the speakers to small and use a cross over at 80hz. On the other hand, the music information when speakers set to small in AVR is much smoother than setting it to large. Somewhere in other forums I learnt that Yamaha messes up between 100 -200 HZ and hence once has the feeling that some information is lost. There it was adviced to send the full range to speakers and do the crossover cut off external and not in AVR.
What I want to do is set speakers as large in Yamaha AVR but introduce a high pass filter in Genelec monitors for 80 HZ so that Yamaha sends full range to speakers and with the high pass filter set in GLM all frequencies below 80 HZ does not get passed to genelecs. BTW, I use 2 SVS 12inch subs and use Minidsp DDRC24 (Dirac) to correct subwoofers. I am also using a RPI4 with Topping D10s to pass additional digital signal to both Genelecs (via SPDIF/AES XLR) and SVS (via Toslink to Minidsp). With the high pass filer setting, the digital signals which are full range can also be filtered to pass signal only above 80hz to Genelec monitors.
Could you please help?
