Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,341
- Likes
- 11,229
When I'll have enough $$$When do you make your move?
I will be listening at 1m or maybe 1.5m, that is now final. You say they are loud, but some people say here that they start clipping with edm. Thats where my dillema comes. Im not after insane spl but i do like to listen loud sometimes and the fact that people are telling me it is not loud enough for edm is a big deal for me as ill spend alot of money on them.The question is always just how much low bass do you need, that's where the limit is for all these speakers. On a desktop, my speakers are 0.5m away and it would be ridiculous to use 8351s or 8361s, the 8331s I have are plenty and they never limit. They take up a reasonable amount of space.
I listen to 8351s at 2.5m and I have to push one to 110dB at the listening position for the limiter to trigger, which is an unsafe level without hearing protection. That's only ONE speaker. The difference is that I have subs.
IMO subs are a basic requirement for seriously good sound and I'll never understand why people are so fixated on avoiding them, especially not with small speakers, which even the 8361s still are. The only no-sub Genelec setup that makes any sense to me is with W371As. You don't have to buy Genelec subs either, they're a nice convenience but it's pretty easy to equal or exceed their performance with a manual setup because GLM sub support is very basic.
And yes manual setup takes some learning and effort, but again IMO if you are spending this kind of money on speakers you owe it to yourself to get a UMIK1 and learn how to measure so that you can confirm you're achieving the results you wanted.
What about the 8351B? How much self-generated noise does that have?One thing to bear in mind is that the 8361s have quite a bit of self generated noise. It is audible if you sit very close to them. I can hear it on mine at 1m, and it sounds like a gentle fan. It is completely inaudible in far field listening. Smaller models like the 8341 or 8331 have little or no self noise in near field use as they are designed specifically for this application.
For me that would be a deal breaker for using 8361s for near field listening on a desk, quite apart from everything else. You will probably be fine at 1.5m but if you plan to be really close - say around 1m - you should expect to experience some noise.
thanks, cant wait!Congratulations! They are amazing monitors!
There is no point in taking the analog out of the Apollo twin and pushing it through an ADC stage to get a digital signal to send to the monitors -- it defeats the purpose of keeping everything in the digital domain.
You basically want to either (i) send the analog outs from the Apollo to the 8361s (i.e. entirely forget about the AES digital plan); or (ii) replace the Apollo interface with an audio interface that has a digital output (e.g. RME Fireface UCX II) that you can then send on to the 8361s.
Either way, you won't notice any difference in sound. It is really more for OCD than anything else (NB. I couldn't help doing this!).
Yes, I forgot to mention that too! I only need something to listen to audio coming from the computer. I thought that is called an audio interface aswell. Do you have any experience with 9320?The 9320a isn't an audio interface, so if you need to connect mics or instruments, you won't be able to use it for this purpose. If it's just for listening to audio coming from the computer, it's a very nice option.
The digital vs. analog input performance is not audible or measurable.thanks, cant wait!
sorry if i wasnt clear enough. I would most definetly like to replace apollo and go digital, not keep it in the chain. Im just asking for recommendation on digital interfaces and opinion on genelecs 8320a and like you said: if its worth it?
thats the thing- apollo is the only interface i ever had and I cant compare it to anything else. I read that it does not really have the best audio input. And thats why im asking.The digital vs. analog input performance is not audible or measurable.
I wouldn't worry about this, and would more focus on getting them set up and listening. Measuring and dialing in with GLM, or whatever. If you are happy with the Apollo Twin, no reason to replace it and would be a waste of good money.
It seems very competent:thats the thing- apollo is the only interface i ever had and I cant compare it to anything else. I read that it does not really have the best audio input. And thats why im asking.
Thanks
www.audiosciencereview.com
Hello all! Thanks for your help. Im getting the 8361a’s delivered tomorrow (i will use them in a bigger room mid field).
Now i have another question: I currently have uad apollo twin mk2 which only has analog outs. I think going digital is the way. Can someone please recommend me some usb to aes solutions? I think going for the Genelecs 9320a is a good way to go since genelec atleast in my eyes knows whats best for their monitors. But i cant find any good reviews about it and even if the added benefits of their controller are nice i dont want to be sacrificing audio quality for them.
Thank you in advance,
have a great day!
