Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,217
- Likes
- 5,454
- Thread Starter
- #61
In my country the S360 ans 1237A cost the same, I'd take the 1237.
I have a quite small living room, but the speakers are already at the limit of this. Also 8361 adds 1000 $ to price (per each vs S360). For a tool, I would pick the "ones", for listening I would prefer S360.
The 8351B is what you should take, not the S360, then.I have a quite small living room, but the speakers are already at the limit of this. Also 8361 adds 1000 $ to price (per each vs S360). For a tool, I would pick the "ones", for listening I would prefer S360.
In what website can you buy them for that price? Thanks.For a longer listening distance S360 is definitely better choice. I was actually initially buying S360 but absolutely fell in love with 8361A as they sound great in different locations in the room thanks to coaxial design. S360 has subjectively the "snappiest" upper bass in the Genelec line up
They measure very well and can be had for 6285 Eur per pair (VAT included) - Very good value indeed.
Hi
. I wonder how serious the bass has to be from such small enclosures... I use 3 subwoofer ( 15 inches) in my HT. Not a matter of SPL, I rarely go over 90 dB, but of scale and heft ... thus I wonder how serious the bass could be, from such smallish enclosures an come to think smallish drivers ... Not saying it can't but ...
I know this flies in the face of what we at ASR hold dear, namely measurements and Science but ...
COVID-19 be damned !!! Slowing the world to a crawl while destroying many lives ... much less important in that scheme of things, I no longer have the luxury to travel and listen/audition... I will at some point, have to go sight unseen or at least on the account of the collective, to make a decision... Sooooo , subjective opinions about the heft and quality of reproduction from these Genelec and equivalent are welcome...
P.S. not talking about the Genelec 1237 or the dear to my mind Neuman KH 420
Same, I've never fallen in love with a 1000 series Genelec. I've heard smaller two-ways and some very large soffit-mounted three-ways. In each case I'm not sure if it was the room, the implementation, the gear, or what, though in hindsight I do suspect more could have been done to flatter them. That said, the 8000 series changed my opinion about Genelec.Has anyone compared 1032C and 8351B?
My own experience is that the Genelecs with the aluminium cabinets (8030, 8040, 8340) have sounded more pleasant in my apartments than Genelecs with more traditional cabinets (M030, 1032C). I also read that the design of 83x1 series could help with rooms that have acoustical problems, also in the lower frequencies. That's why I started to wonder how 8351B could sound in my listening room...
The 1000 series is more "harsh" sounding, plus the cabinets are less suitable for home use(diffraction issues)Same, I've never fallen in love with a 1000 series Genelec. I've heard smaller two-ways and some very large soffit-mounted three-ways. In each case I'm not sure if it was the room, the implementation, the gear, or what, though in hindsight I do suspect more could have been done to flatter them. That said, the 8000 series changed my opinion about Genelec.
The S360 is designed primarily to deliver high spl. Not something you need in a small living room, unless you want to damage your ears really quick.Why? If in my small living room the speakers are already around 3 meters away (from each other and from the main listening point), the S360 would be a better fit (now imagine that in decent size living room). I have used 8040 and 8050 on the same room and I can say that staying at the same size (going with 8351) is not an option to me (I would gain a bit because of new design, but nothing ground breaking). Bigger is better as long as you can fit them to room nicely.
I wish it had an aluminum cabinet x it would have been much coolerThe S360 is designed primarily to deliver high spl. Not something you need in a small living room, unless you want to damage your ears really quick.
Designing a speaker is a matter of making compromises. The quest for very high spl will probably lead to less finesse.Perhaps, but it also fills the room better as the direct sound waves dominate over reflections. That is always a good thing. This is also a reason why bigger is often better, even in small rooms. Bigger speakers can fit a larger wave-guide.
