Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,217
- Likes
- 5,454
That's exactly it lolKH420 has a better bass: less distortion at loud levels and ability to go lower.
The hiss is also more quiet with the KH420: 18.3 dBA SPL against 24dBA SPL for the 8361A.
And... that's it.
But I am convinced that if you want the best sound in the world you will need a subwoofer. Why?
Of course all of this is possible only if:
- Unless you listen to music in a perfectly treated room in a dedicated room (is such a thing real in this world?), you will have a hard time finding a place for your pair of speakers where the frequency response is flat in the bass region. Therefore, a sub will allow you to put your speakers at the best possible place for a nice response down to ~100hz. As for the bass, if you delegate the job to a sub, you can move it in the room to find the best place while you can still seat at the same location with the speakers located at the most convenient place for you. Of course you could add a second subwoofer to optimize and fill dips you weren't able to cover with the 1st subwoofer.
- Subwoofer are made for bass, they're heavy as hell (is hell heavy? good question), their driver is really made for the sub 100hz region while woofers on speakers often have to handle up to 300-500hz to take over the mid-range driver. Therefore, a 18 inches driver will without a doubt have less distortion than an 10" woofer (KH420, 8361). It will go lower, it will go louder.
- The bass woofer of your speaker will have less work and therefore will be better in the high bass region and will be able to go louder.
- The subwoofer is very good (not all subs are equal)
- You are able to integrate the sub perfectly. In my experience, I was never able to do that before I met the GLM kit. You'll certainly be able to do it for most setups/brands using REW software and a microphone, but it will require a lot of time and knowledge. What GLM offered me is an outstanding "click and play" experience. I won't go into GLM's autophase and woofercal processes details but I find it to work very, very well.
@Pearljam5000 unless you don't care about wasting money or you can't mentally handle the fact you don't own the biggest Genelec model, you'll end-up with a pair of 8351Bs and a 7380A sub That is your endgame.
It's very hard to know that there's bigger and better and you buy the second best model lol
A sub would be great but Unfortunately Genelec subs are overpriced
Obviously if it was easy to integrate an SVS sub that costs 1000$ that would be more realistic
