I'm not entirely sure the difference will be that big.
Salon2 is 3 8" woofers.
8361is 2 8.5"? drivers.
Salon2 is -3 at 23Hz
8361 is -6 at 30Hz
That extra extension(not insignificant) is gonna eat up a lot of the Salon2's headroom. I actually wouldn't be that surprised if the Genelec could play louder, given that it limits the extension. Just a guess, but I'm guessing the Genelecs woofers are probably also more advanced(just based on the year they were made), and probably more similar to the F328Be's woofers. The F328Be, with it's 91dB efficiency and 35Hz -3dB would almost certainly beat the 8361 in an SPL contest.
I'm not sure what "Peak SPL", "Short term" and "Long term max" means, but Genelec specs the 8361 at 124dB, 118dB, and 109dB, respectively. Given that the Salon2 is 86dB sensitive, it seems like it would take an almost impossible amount of power(does any wall even give that much?) to reach those SPLs. How much power would it take for the Salon2 to reach 124dB, 118dB, and 109dB at 1m?
Sorry my bad, THREE 8" woofers.
Yes it could be much closer.
Genelec specify:
Peak SPL
Maximum peak SPL output
per pair on top of
console at 1 m with music material.
Short term max SPL
Maximum short term sine wave SPL output at 1 m on axis in
half space, averaged as specified (
from 100 Hz to 3 kHz).
Long term max SPL
Maximum long term RMS acoustic output in the same conditions with IEC weighted noise (limited by driver protection circuit) at 1 m.
Bold is inserted by me, to emphasise factors that affect SPL.
Genelec engineers are clever, and cost conscious- t they don't use state of the art transducers or amplifiers (again, ask
@Ilkka Rissanen based on his subwoofer tests) but use clever implementation of
good enough. It all depends on the drivers themselves.
At the low end dynamic limits are directly related to the amount of air displacement. This is called the displacement limited SPL. It doesn't matter how much power you put into the speaker, 100W or 2KW, the cones just cannot move anymore past their suspension limits. So Genelec's 15" woofers are always going to play cleaner and louder below the displacement limited frequency than a their ovoid 8" woofer.
Anyway, amirm's data at 106dB is very instructive- the amps are already clipping and the top end is shelved down about 10dB, and the sub-bass (50Hz or lower) distortion is already at ~-14dB; which is about 20% distortion.
So could you crank it up some more to get to 109dB? Probably, but you lose a bit more as well. In general peak SPL refers to instantaneous peaks, which may be possible around 1Khz, but only for fractions of a second eg. 200-500ms, attack phase of a pair of crash cymbals.
The Salon 2 is getting a bit on (about 12 years old) and 8" drivers of that vintage have about 7-9mm one way, probably.
86.4dB/2.83V into 4 ohm = 2W
96.4dB = 20W
106.4dB = 200W
SoundStage Hifi showed the Salon 2 tweeter was just starting to show mild signs of compression of about 2dB loss, when tested at 95dB compared to baseline (70dB), so the dynamic limits at the top end are probably around a similar ballpark to the 8361.
We all dream the day at amirm posts his 86dB, 96dB and 106dB distortion tests on his Salon 2 and put us out of our misery and stop with our SWAG (scientific wild arse guess)
