Hi!
I think I am ready to take a big leap forward and order a pair of 8361a (current setup: Kef LS50 wireless + SVS 3000 Micro).
A couple of questions though:
- I have seen a couple of reviews mentioning some "fatigue" during extended listening sessions. Has anybody experienced anything like that?
- My bigger concern is the source: does it make sense to go for a Wiim Ultra and use a SPDIF/AES converter? Or better go for a streamer that would already have balanced outputs? Any recommendations here?
- Last, the speakers will be placed on a bookshelf with very little room on the sides and back. Is that a red flag or will GLM help correct it anyway?
Cheers.
Your current setup is already very good. In case you already apply room-correction and have properly integrated the sub, I wouldn't expect a night and day difference in perceived sound quality from the upgrade apart from the obviously much higher SPL capability.
Regarding your questions:
- FWIW, I have the much more mundane 8030C and find them slightly on the bright side, which I suspect is due to their wider high-frequency dispersion than, e.g., some Neumann or KEF designs. I listen to them near-field and do not find them fatiguing though. In any case, with GLM you could tilt the top end down slightly to taste.
- As
@kyuu mentioned, a WiiM with digital out is an excellent choice and avoids unnecessary (albeit likely transparent) AD/DA conversions. If I remember correctly, if you keep the cable run short, you might not even need a proper SPDIF/AES converter. A simple rca/coax -> XLR will probably suffice.
- GLM can help a lot, especially in the bass region, but it cannot fix SBIR issues or asymmetric early reflections caused by compromised placement. If I were spending ~10k on a pair of speakers, I would definitely also think carefully about placement and at least some mild room treatment.
Enjoy your new endgame speakers! Cheers!
