I don't use a remote, but I'm not certain if there is one to link in with the 9320A. I don't believe so though.Yep, that cheap switch, or similar, would be enough.
Just route the digital signal to the AES/EBU input.
You shouldn't even need an impedance transformer.
P.S. Can the 9320A be controlled remotely?
A remote control or through the software on the computer?
Thanks
However, if you have GLM 5 on your computer, you can control volume etc from that. My Dell XPS-15 is linked into the 9320A by usb and does a good job here.
Sorry, I should also have said that the cheaper option wouldn't really work in my set-up as I use one coax input for the DAB on my tuner and the optical final (fourth) input for the FM/AM on that same tuner (the latter linked through an analogue to optical converter). Hence, I do need all four inputs of the RDL. Others obviously might not, and then they'll literally be quids in.
