sleepy.sock
Marcel is great!
Can you share some details about your room size, listening distance, your normal listening levels etc.?As said above, I am now experiencing the 8361's with the 7360's at a superb level. While the 73X0 series subs are not designed to go with the 8361's, they can produce music of a phenomenal beauty and accuracy once dialled in. That is not to say that they can ever achieve the performance of the 8361 and W371 combo, but that is the designed partnership at the top of Genelec's the Ones monitoring system. If you ever have the chance to audition that combo, I would very, very strongly recommend that you do so. From top to bottom, I believe that this is as good as stereo reproduction gets in the home listening environment!!
Anyway, on the torturous road to perfecting the performance of the 8361/7360 combo, Marcel's above webinar has proven invaluable and I would just like to share a couple of key lessons/tips learned in achieving this.
1. Start by finding the ideal position for the 8361's. This will invariably be near to the front wall and can also involve them being close to the side walls as well. I will post another clip that reinforces Marcel's point about the advantages of positioning your speakers there. This can be greatly aided by using the GLM to test them as a stereo pair. Here you just need to continually run the autocal and assess which position gives the best frequency response, removing troughs and flattening out the response. This can involve finding the ideal position for each monitor separately and will give you a much wider soundstage. It will also minimise room modes and make it all much easier to optimise the position of both monitors.
2. Once you've optimised the stereo performance of the 8361's, introduce the subs in a more central position with them now driving the monitors. Here you should set the cross over at a point that best covers the range of your key trough (for me that was cross over at 80Hz - to fully cover a 6dB trough at 76Hz). Here you run the GLM autocal and autophase for the new group consisting of the two monitors and two subs. This will provide performance of an amazing quality - just not at the ridiculous levels of the 8361/W371 combo.
So that is my strongest advice and I'll now share the promised clip that strongly supports Marcel's placement suggestions, which underpinned the above findings.
Of course.Can you share some details about your room size, listening distance, your normal listening levels etc.?
I also have 7360 and have been eyeing for a bit larger speakers and would like to know is the sub struggling to keep up with the 8361 at reasonable and not so reasonable levels 80-95dB.
Thanks! That is pretty much the same area as my room, this is a converted attic space so 1' lower ceiling that slopes towards the front.Of course.
The speakers are 10' apart and my listening position is 10' from each speaker. The listening room is approximately 14' x 12' x 8.5' (LvWxH). I generally have my Topping Pre90 set at -36dB, which gives me an average SPL of 75-85dB. I do of course have sessions where these levels are exceeded and health cares ignored.The first and second point reflections are treated with GIK absorbers.
On the sub and the 8361's, not really. Yet, imaging, timbre and dynamics are not the same as when they are partnered with the intended W371's. And yes, the 7360's are more than capable of running with the 8361's up to 95dB and beyond (118dB),
Running my 8361a using analogue inputs at the moment. My dac does have an AES/EBU output - I would need to source appropriate cables.
Question - is digital input only a theoretical improvement (I get the adc-dac thing) with these speakers? I mean I can not find fault using analogue inputs?
Not sure if my Okto dac has volume control ovet AES/EBU output.
I recommend that you move the speakers away from the front wall ~ 1m and add diffusers behind them. Move your couch and side absorbers closer towards the speakers, increasing the ratio of direct to reflected sound. This has dramatically improved my listening spaces.
That's exactly what is NOT recommended by Genelec because of SBIR (cancellations), have a look here.I recommend that you move the speakers away from the front wall ~ 1m and add diffusers behind them. Move your couch and side absorbers closer towards the speakers, increasing the ratio of direct to reflected sound. This has dramatically improved my listening spaces.
Thank you for everyone‘s comments so far.That's exactly what is NOT recommended by Genelec because of SBIR (cancellations), have a look here.
Instead, leave the speakers where they are and move the couch towards the middle of the room. Not exactly to the center because typically this area is dominated by cancellations, while at the back wall you will be sitting in a bass dominant area. Also by reducing the distance to the speakers the sound will be less influenced by the room (better early vs. late sound ratio, currently marked red in the report).
Regarding the absorbers this looks fine to me. I have placed several smaller absorbers and also GIK bass traps at the ceiling of the back wall in my small office and reduced RT60 a lot. I remember a quote by an acoustician who said better apply too much absorption than too little.
Agree with you - mine are white too. And my Gibson Les Paul Studio is similar as your guitar in the picture, if I am not mistaken: black and golden hardware.I wonder What % of the 8361 owners on this thread bought them in white
Because to me that's the best color
