Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 7,740
- Likes
- 9,705
It says that Genelec is in Lisalmi, Finland (A Facebook location thing)What's the Finland reference? Or am I just misreading the word?
So you read it correctly
Odd that they'd mix the scripts like that... but not being a Face-thingie user, the peculiarities never occur to me.It says that Genelec is in Lisalmi, Finland (A Facebook location thing)
So you read it correctly![]()
Depends.So is it possible to call the 8361 "full range"?
www.audiosciencereview.com
Depends, for me, yes it would be full range. I wouldn't use them for movies, listen position would be 2 - 2.5 meters and The Beatles Come Together or Nilisson Jump Into The Fire are good examples of bass requirements.So is it possible to call the 8361 "full range"?
Good to know . I am not buying sub till I finish room treatment.Just a quick update. I've currently removed my pair of subs and am running the 8361A's as a stand-alone stereo pair. This has lost me 9Hz of bottom end in room response (from the 14Hz with the subs up to 23Hz on their own). That results in a slightly less full and solid imaging. However, it cleans up performance and brings out detail, dynamism and tonality in the 8361A's. Worth trying for those using small to medium sized listening rooms or studios.
100% agree with this. Sometimes domestic peace is non negotiable.Just a quick update. I've currently removed my pair of subs and am running the 8361A's as a stand-alone stereo pair. This has lost me 9Hz of bottom end in room response (from the 14Hz with the subs up to 23Hz on their own). That results in a slightly less full and solid imaging. However, it cleans up performance and brings out detail, dynamism and tonality in the 8361A's. Worth trying for those using small to medium sized listening rooms or studios.
It’s more than enough.To my knowledge, full range usually means 20Hz to 20Khz.
In my room the 8361s measure from 25Hz at-3. That’s maybe not entirely, but pretty full range.
Knowing both of the mentioned Sopras. They don’t play deeper despite their size.
Depends on the SPL requested but yes at higher SPL it will have more distortion.Doesn't make sense. 8361a should now have more distortion without the sub.
Sounds like you may not have had the crossover to the sub calibrated properly. Obviously mids and tweeter should be the same.
And yes I have tried it.
More likely one of those purely subjective things that don’t exist.Okay, so here's an interesting one. I and another experienced engineer both experienced the same thing, without prompting, about the mids and highs on the 8361: they're kind of "washy"/indistinct sounding.
Is there anything in the measurements that would indicate why this is or is this one of those purely subjective things that we don't have a good way of looking for yet?
