I mean how could anything surpass them? If we're talking about the desired objectives being anechoic flat and good horizontal & vertical directivity. Ok, I mean the speaker that would surpass them would have to go flat down to 20Hz and would have more power than this speaker with lower distortion at 96dB and maybe even at higher SPL - so I think it's just bass extension and even higher SPL whilst retaining low distortion that would beat these.Maybe we can take bets on whether something will surpass them this decade.
Maybe they will add subs like on D&D 8CI mean how could anything surpass them? If we're talking about the desired objectives being anechoic flat and good horizontal & vertical directivity. Ok, I mean the speaker that would surpass them would have to go flat down to 20Hz and would have more power than this speaker with lower distortion at 96dB and maybe even at higher SPL - so I think it's just bass extension and even higher SPL whilst retaining low distortion that would beat these.
With my current understanding, I don't really see any downsides of integrating a sub into a speaker (I mean it would make it 3 or 4 way (is there a 4-way speaker!)) - and it would increase the weight & size substantially if you were talking high SPL and low distortion at those deepest notes - I mean you only have to look at how heavy and large subs are that hit 20Hz at high SPL. Ok, so the downsides are size & weight! (price comes along for the ride)Maybe they will add subs like on D&D 8CView attachment 244643
A version of the Ones with built-in cardioid bass capability(rather than only available via the W371A) would be better. But that would require a significant redesign and re-tooling of their manufacturing so it probably won't happen for a very long time, if ever.mean how could anything surpass them?
It will probably be difficult to make it smaller and at the same time compatible with 51 and 61 speakers. In that case it would be designed for the 31 and maybe 41?A version of the Ones with built-in cardioid bass capability(rather than only available via the W371A) would be better. But that would require a significant redesign and re-tooling of their manufacturing so it probably won't happen for a very long time, if ever.
The more realistic hope is that they do a smaller version of the W371A that is at least somewhat cheaper.
Yep I was at a point wishing for this. Then I realized how much bass you need to power a typical open plan layout.It will probably be difficult to make it smaller and at the same time compatible with 51 and 61 speakers. In that case it would be designed for the 31 and maybe 41?
I believe that you need the current size to get the volume and impact of the sound that 51 and 61 requires.
In one of the Genelec reviews (the 8351?) he says he used a Topping DAC and a digital connection, but also remarks that Genelec (unsurprisingly) says it doesn't matter which connection you use.@amirm when you tested these speakers, did you connect them via the digital or analog inputs?
I think they may be starting to realize the market potential.It would be nice if Genelec opened up to the hi-end market. No, I'm not kidding. They could make something like the 1236A, but with a friendlier look - not necessarily WAF, just generally a more "homey" look.
Could certainly be smoother 200-4000Hz. Not much, but a bit.I mean how could anything surpass them? If we're talking about the desired objectives being anechoic flat and good horizontal & vertical directivity. Ok, I mean the speaker that would surpass them would have to go flat down to 20Hz and would have more power than this speaker with lower distortion at 96dB and maybe even at higher SPL - so I think it's just bass extension and even higher SPL whilst retaining low distortion that would beat these.
Oh yeah? Which monoprice sub plays cleanly without breakup to 500hz?Those W371 are really expensive for basically being a Monoprice SUB in a taller box with a small computer in it. They should be around 2500 a piece.
True about the price, in terms of theoretical speakers that could surpass this one! Do you know what Toole meant exactly by "variable directivity"? My understanding is that smooth & wide directivity both vertically & horizontally is optimal according to their research, as seen in this speaker.Could certainly be smoother 200-4000Hz. Not much, but a bit.
Same performance for cheaper would certainly 'surpass' them. This is certainly do-able by making a speaker with exactly the same capability above 80 Hz, but not below, and designed for use with subs.
And Floyd Toole says it would be desirable for speakers to have variable directivity. OK so it's difficult, but it's a direction for further progress.
cheers
He meant user-variable.Do you know what Toole meant exactly by "variable directivity"?
Correct. But it could still be adjustable. To allow for different room reflectance, or size, or speaker placement; also for using the same speaker for different program material eg 2CH and MCH; also to allow for many recording engineers being much more sensitive to reflections/spaciousness than 'ordinary folk' and making mixes too dead. In a normally-reflective home environment one could adjust the directivity to suit the situation.My understanding is that smooth & wide directivity both vertically & horizontally is optimal according to their research, as seen in this speaker.
Ah, I roughly see what you mean - well as you said, that does sound like a complicated thing to achieve in a speaker, sounds like it would involve actually changing shape of waveguides and other physical aspects of the speaker construction that influences the "wave front" if that's the right term, so the speaker would have to change it's physical shape in those areas at the users command (to be variable), I would think?He meant user-variable.
