Genelec 8361A Measurements and Multitone comparison with other speakers.
Nuyes
Reviewer
South Korea
Hi, I measured a pair of Genelec 8361A.
And I have attached multitone distortion comparison data with other loudspeakers, so I hope enjoy it.
Frequency response
This is 3-way loudspeaker.
I'm using near-field measurement(LF) and window gating(5ms, 1m distance) to get a frequency response,
so I can't measure perfectly(of this design).
Therefore, I hope you enjoy this data(Frequency response) only for fun.
Next,
Directivity
Likewise, they have a 5ms window.
Beamwidth
Polar plot
THD
Measured at 85/95dB SPL@1m.
Very clean!
Next is THD comparison. (Sample A and B)
The owner of these loudspeakers told me, "The 3rd HD is slightly different."
So, I measured them.
It's interesting.
Sample B is higher at 85 dB SPL, but mitigates back to the same level at 95 dB SPL.
But I know this is a tricky nitpicking.
They're still close to perfection.
Next,
Multitone test
85dB SPL@1m
The data limited to 80Hz or higher, and the deviation between samples are all beautiful.
Multitone test(Increase level)
76dB SPL@1m ~ 96dB SPL@1m
Most impressively, the measurement data of 76 dB SPL was not measured properly because it was low enough to be buried in the background noise of the measurement environment.
This speaker is insanely clean.
And furthermore, even when we increased the level from 86dB SPL to 96dB SPL, MD didn't grow any more.
Compression test
Wow.
I'm really lost for words.
(This is not because I am not good at English.
I have a Google translator, LOL)
Next,
Frequency response deviation between the 2 samples.
Very little deviation.
I hope you enjoy these data.
Next, part2.
Nuyes
Nuyes
Reviewer
South Korea
It's part2 now.
Multitone test comparison
The speakers used in this comparison are the products I measured before.
We selected and compared some products that have good multi-tone distortion performance.
Among them are personal DIY works from other Korean.
Genelec 8361A vs 8351B
BeAR159
This product is custom-made by Jinsung Ko in Korea.
(Currently sold out.)
KEF Reference 1 Meta
KEF R11
Panda MK1 by Jinsung Ko.
This work is a DIY.
(He also made the BeAR159.)
KEF R3
Arendal 1961 Tower
Arendal 1961 Monitor
Arendal 1723 Monitor S THX
Kali Audio IN-8
The following is a comparison at 96 dB SPL@1m.
This time, the tone used for the measurement is not a flat curve, but a music curve.
The fundermental level of this measurement data is -40dB.
So consider the +40 dB offset from data and enjoy it comfortably.
Genelec 8351B
BeAR159
KEF R11
KEF R3
Arendal 1961 Tower
Genelec 8331A
Kali Audio IN-8
Finally, ported/sealed comparison data for speakers that officially provide port cap.
KEF R3
KEF R11
Arendal 1961 Tower
I hope my poor English has not caused you any inconvenience.
Enjoy these data and have fun discussing them!
tifune
Which of these tested is the best bargain?
it depends on your circumstances but I'd lean toward used R3, usually can be had for $1200 shipped in US. Less if you're patient
In-8 also great for the price, not really a looker like R3. Whether that matters to you... Would need to know more to give any meaningful answer
Nuyes
Nuyes
Reviewer
South Korea
Thanks for posting them. And I realized now I didn’t notice to you that I changed my account! My bad
Very interesting measurements, thanks for posting them.
This measurement looks odd, I don't see why sealing affects the mid and tweeter a lot.
It could be a leak from a official sponge to block the port.
Or it could be a QC problem for the measured sample.
So, I wanted to get samples for additional measurements because there was nothing to know exactly, and an anonymous user decided to send me a pair of samples.
I'm going to measure them this Saturday.
abdo123
Brussels, Belgium
This is a tell-tale sign that the noise floor between measurements changed and / or is higher than the level of distortion. there is no other logical explanation.
GXAlan
Nuyes
Nuyes
Reviewer
South Korea
It is possible to automatically repeat the measurement several times and calculate its average to eliminate the impact of the noise floor(random noise).
And this difference was also found in mid unit nearfield measurements.
Kervel
Nice measurements, thanks! I was surprised that the Arendal bookshelf has so low MD (even better than the tower in the Arendal series). The reason is that Erin's review shows it to roll off very early. If you dont play deep bass, it wont distort either I guess.
Nuyes
Nuyes
Reviewer
South Korea
I agree with you.
And because they also have a difference in the volume of the box, I'm guessing that even if they're in the same sealed mode, there's this difference.
Nuyes
Nuyes
Reviewer
South Korea
It's part2 now.
KEF R3
I thought the MD difference on this data was too big, and there was a big question about this.
Meanwhile, someone sent me a pair of R3.
Before look at the measured data, I have something to explain.
This is entirely my mistake,
I had already measured R3 once in April 2022 (existing data), and at that time I had not properly organized the project files of Klippel software for measurement.
Therefore, there was a mistake in the SPL setting for this re-measurement, and this measurement was conducted at 82 dB SPL@1m, about 3 dB lower than usual.
For this reason, I inform you in advance that this measurement is impossible to compare fully with the old data.
However, I measured a pair in the same condition.
The deviation data between the two samples is significant.
Data from sample A.
In addition to the 82dB SPL@1m test, we have enclosed data that limits the test signal below 80 Hz.
Now it's the comparison data.
Ported mode and both sealed mode(sponge & blanket) were measured.
The reason I did this was because I had to leave open the possibility that the high MD of the previous measurement was due to the leakage of a official sponge.
It's very clean!
The sample B is also clean.
Certainly, Sponge doesn't seem to be at fault.
This is a comparison between two samples.
No significant difference was found.
And this is a measurement at 93 dB SPL.
(Genelec 8361A : 96dB SPL@1m)
And let's compare it to the old data that I measured in April 2022.
This is the conclusion so far.
Of the three R3s measured, MD increase by closed mode was found in only one sample.
Therefore, this seems to be a problem with one sample itself, which was previously measured.
And while I was measuring this pair, I also measured the frequency response deviation between the two samples.
The deviation around 1kHz may be a sample problem, but I think it's a little different.
The owner of the loudspeaker saw the 'Shadow Flare Position Impact on Frequency Response' issue introduced in Erin's Audio Corner (EAC), and then repaired it himself.
(Just press it.)
But he is also human, so it is difficult to push the shadowflare of the two samples equally, and I think this is contributing to the response deviation around 1kHz.
And apart from this, a deviation from the tweeter was found.
This pair of samples has a neighboring serial number.
I think this measurement is good to solve the question about MD(Sealed mode) of KEF R3.
outfaced
EU (BG)
interesting indeed ... refernce meta 1 with the worst cost/distortion ratio :D
the small kali actually quite good for the money
good work !
