That's similar to the one I bought.
Grabbit Speedout Pro.
Unfortunately, it didn't work
. I've got rubber bands coming tomorrow, but I'm really doubtful they'll work given what I've already tried.
Thanks. I reached out to sweetwater, but didn't think to reach out to Genelec themselves.
Just needed to vent here
. Spent 4 or 5 hours messing with it yesterday. It hit me thinking about it in bed last night that I can just switch the center and left channels(since I like the look of the center better horizontally). Then tonight, after work, I carefully unhooked all the cables for left/center, and I go to make the switch, only to discover that one of screws on the center channel is stripped too, then after I hook everything back up I gently set the center channel back on the stand, and that's when the other screw(not the stripped one)breaks in half
.[/QUOTE
I am guessing that Genelec does not clean the threads after the coating/painting process and the excess paint results in extra torque required on the bolts. not a good comb with the soft and small fasteners used for the isopods. I hope you are able to remove the broken bolt, real bummer specially at this price point.
