Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 7,394
- Likes
- 9,067
How surprising that a manufacturer says his product is better than another brand's product
The frequency axis you posted starts at 920Hz and ends at 1.1kHz. The resonance shifts to lower frequencies when you use damping material.Oh good grief, that is the impedance plot!!! Right hand scale on the REW plot, 7.3 to 8.3 Ohms.
So where does the "newNo, you misinterpreted the plot I posted. And there are no differences in resonances at in the impedance plot or any other plot in those smaller resonances at the other frequencies. The real big resonances like the actual breakup mode are what should be focused on, not the stuffing. Funny you talking about all of this resonance stuff in reference to this particular Genelec speaker. You are running wild!
That's huge! Not.The frequency axis you posted starts at 920Hz and ends at 1.1kHz. The resonance shifts to lower frequencies when you use damping material.
So where does the "new" resonance in your plot come from?
) is less effective than the single layer of Polyfill. In that case, thanks for pointing out how effective Polyfill is.So it has a breakup mode at 6K, but then using a steep crossover which would minimize the effect of that on frequencies outside of the driver's band is somehow also bad because of the not-fully understood-audibility of the resulting change to the *step response*???It's pistonic over its passband, but apparently the mid has quite the breakup mode around 6k and that shows as a H3 peak around 2k.
He is referring to this 2kHz harmonic distortion peak, right?It's pistonic over its passband, but apparently the mid has quite the breakup mode around 6k and that shows as a H3 peak around 2k.
That's huge! Not.
Seriously, no idea. I got the mic as close to same position run to run. But no way exact. May be mic position. It's why I included distortion, and more importantly impedance.
Maybe the single layer of Jute (the purple trace that you highlight in your high-mag zoom) is less effective than the single layer of Polyfill. In that case, thanks for pointing out how effective Polyfill is.
Let's talk about Polyfill, since that is what Genelec uses in the midrange, and lots of people seem intent on avoiding Polyfill, like many of your comments ('not so effective', etc.) Let's put aside the midrange non-issue and look at the impedance plot of the system resonance with different stuffing compared to no stuffing:
Single layer of Polyfill (green trace) is more effective at changing system resonance than even two layers of Jute. So perhaps that residual resonance with a single layer of Jute is due to the fact that Jute (and many so-called denser/better/costlier) are actually less effective than Polyfill.
It's absurd we are talking about tweaking this Genelec speaker, especially based on so many misstatements of the effects. So you are clear, I am done with the discussion.
just dug into the Knif post and it sounds funny... apparently he measured the Genelec nearfield (he didn't mentioned, but hinted in his response), and then he measured his speaker far field and gated it, IME that alone would affect the data quite a bit?IIRC Jonte Knif measured this, let me see if I can find it again. I'll edit when I do.
EDIT:
Those are different models, Knif had 8351A and Amir 8351B, all drivers were changed, tweeter is bigger, midrange cone is completely new and woofers uses different cone material (and different amps, and crossover points)He is referring to this 2kHz harmonic distortion peak, right?
Yeah, it's huge. Once you make a speaker with low distortion, every remaining resonance becomes evident.
Thing is, I don't see any evidence of a 6kHz breakup mode in the composite mid/tweeter data? Maybe if we had measurements of the mid alone, but it doesn't appear in measured response. I do see a resonance at 30kHz (!) in Knif Audio's measurements, with a 3rd HD peak at exactly 10kHz.
Or maybe this is what Amir measured when he pushed the speakers:
Is that the amp limiting causing artifacts that show up as distortion?
OK, thanks. I missed that!Those are different models, Knif had 8351A and Amir 8351B, all drivers were changed, tweeter is bigger, midrange cone is completely new and woofers uses different cone material
The inside looks so cheap and they charge so much money!!View attachment 125978View attachment 125979View attachment 125980View attachment 125981View attachment 125982View attachment 125983View attachment 125984View attachment 125985View attachment 125986View attachment 125987View attachment 125988View attachment 125989View attachment 125990View attachment 125991
Second time, I disassembled my 8351B again.
This time, I opened the speaker driver side and took a picture in more detail.
I wanted to disassemble the tweeter, but it was glued so I couldn't remove it.
The woofer looks like paper and the center is filled with solid foam.
The mid-tweeter driver is not directly screwed into the enclosure, but is pressed by the rear panel.
The notes on the amp module are curious.
This is 8351B, why is the amplifier module marked as 8341A? It seems to be a compatible part.
Then, I hope you enjoy it.
I think you're paying mostly for the tech and SQ and less for the parts costThe inside looks so cheap and they charge so much money!!
The can mount with stand-plates made to fit the Iso-Pods:sorry for sneaking in with a truly basic question: can anyone tell me the surface required for the 8351 iso pods?
thank you!
Nothing looks "cheap" there. As a mechanical engineer I would say it just looks like good engineering. What do you expect? Do you miss veneer or something?The inside looks so cheap and they charge so much money!!
Until you look at the huge magnet and voice coil on the midrange. It's really an impressive driver.The inside looks so cheap and they charge so much money!!
No just saying it is too expensive for such a spartan design! Love the speakers but not the prices especially since the dealer margins are 40 points off the MSRPNothing looks "cheap" there. As a mechanical engineer I would say it just looks like good engineering. What do you expect? Do you miss veneer or something?
This is probably the best coaxial design you can get, also no need for an amp or dac. Room correction is "only" a 300 Euro upgrade (though it should be included in my opinion). I have tried several other room correction options over the years (REW, DiracLive for PC, Audyssey and Dirac on Denon-AVR) and found GLM to be the most accessible solution for me. So besides the speakers the additional equipment needed is actually very cheap compared to traditional hifi-setups. For studio use the pricing is not that important, but you pay for the engineering, reliability and long-time support.No just saying it is too expensive for such a spartan design! Love the speakers but not the prices especially since the dealer margins are 40 points off the MSRP
In most countries buyers are generally not paying MSRP for Genelecs, FYI.No just saying it is too expensive for such a spartan design! Love the speakers but not the prices especially since the dealer margins are 40 points off the MSRP
