I am kind of missing the impulse response here. Would it be possible to feed the speaker a super short signal and see how well the membrane follows?
I will edit and add "total" ... to at least $24,000 ...In these objectivist parts of the audiophile world, you’d have to be at least a little bit crazy to spend $22k in amplifiers to power $15-20k speakers, when we know it’s not going to make an audible difference other than total power delivery.
A few thousand for some good Hypex or Purifi amps is likely all you likely need. Several Salon2 owners even just use Benchmark AHB2 amps which aren’t nearly as powerful and are very happy with them and don’t run into the clipping indicator.
For some reason your measurement above has ten times the bulk delay there is in reality. Correct bulk delay for 8351B is about 3.1 ms (for analogue input >1 kHz).
Oops my mistake for totally misinterpreting you. Yeah, it takes at least a few thousand dollars to get a powerful amp competent enough for the Salon2’s. The remaining difference is that the Salon2’s often are on sale while the 8351B’s never go below Genelec’s controlled price in the US market.I will edit and add "total" ... to at least $24,000 ...
I read in another post that you are moving to NYC - when is the housewarming party and how do I get invited please ?It’s worth pointing out that Amir didn’t say the Salon2’s go louder, but that their bass goes much louder (and deeper). This should be a surprise to nobody, given that each Salon2 has 3x 8” high performance (sub)woofers in a 4-way speaker, vs the equivalent of just one 8” woofer on the 8351B as a 3-way speaker. When subwoofers or the W371 is involved to unload the bass power, I wouldn’t be surprised if the 8351B at least matches the Salon2’s SPL capabilities.
For movie content, I actually found my Genelec 8351B’s (when crossed with subwoofers) to in some ways sound more “dynamic” than the Salon2’s. But I don’t think this is due to any actual heard distortion at the levels I was driving them, but rather because the 8351B’s narrower beam gives a somewhat more frontal and energetic feeling vs the more spacious feeling of the Salon2’s.
P.S. I own Revel Salon2’s and Genelec 8351B’s and have written subjective impressions comparing them around these forums from time to time. I’ve owned and lived with the 8351B’s for a while now, though Amir has much more ear time with his Salon2’s. I’m happy to answer any other questions about subjective impression differences between these, but my impressions I’ve written (which you can find in my post history) essentially match exactly what Amir has said (though I go into a bit more detail with where I find the 8351B’s strengths win out, and similarly what scenarios the Salon’s really shine).
This raises the question of sensitivity. In a surround application could they go to sleep and then wake up but with a delay to the output?
Hi,
You can adjust both sleep delay (2 min - 4 hours) and sensitivity (three steps) from the GLM.
Same here. It doesn’t work with aes.I've never been able to get sleep through ISS to work using AES3 input. It says something in the manual that it might not work using digital in as the source keeps a signal to the speaker. Am I not understanding something? I keep GLM connected (not to computer) and use the remote to turn everything on and off.
Is feeding "The Ones" with a DAC-less digital AES/EBU input from a simple streamer (such as an AES/EBU hat onto a RoPieee running Rpi4, for example) instead of a high SINAD DAC's analog output expected to give similar results or not?
In other words, does anybody know how "The Ones" embarked digital to analog conversion compare with top rated DACs feeding them?
(Trying to find the best quality, simplest and most direct way to connect 8351B to a Nucleus.)
P.S. Very many thanks for the review!
Will the built-in DAC ruin it or is it transparent? Contradiction detected.I think there is always an AD/DA loop when you feed the Ones with analog. No point to invest in an expensive dac, the built-in one will ruin it
I am pretty sure the builtin one is transparent.
The analog signal will be converted to digital anyways. might as well avoid the additional conversion and feed the speakers directly with digital.Is feeding "The Ones" with a DAC-less digital AES/EBU input from a simple streamer (such as an AES/EBU hat onto a RoPieee running Rpi4, for example) instead of a high SINAD DAC's analog output expected to give similar results or not?
It is true with all speakers then, not only Genelec with GLM.Another way to phrase it: a 120 SINAD dac will be wasted ; it can still be very very transparent. Overtime I do a blind test between 2 dacs I get convinced that dac doesn't matter at all.
There is a subtlety here that is perhaps being missed: An audibly transparent DAC is only referring to a single conversion pass. Every extra time you convert back and forth just keeps adding more and more distortion. In reality, you can probably do this quite a few times without getting audible. But if you pass a signal through any DAC > ADC > DAC > etc. enough times (even if each DAC/ADC is audibly transparent for a single pass), I think you’re eventually going to reach 100% distortion (it may have to be hundreds of passes to get there though)Will the built-in DAC ruin it or is it transparent? Contradiction detected.
No plans yet, but this could lead to some interesting potential opportunities for a Salon2 vs 8351B shootout / blind test with a good number of listenersI read in another post that you are moving to NYC - when is the housewarming party and how do I get invited please ?
