- Joined
- Jan 23, 2020
- Messages
- 4,511
- Likes
- 7,113
I know this is the 8351B thread, but it's that same thread that put the 8361A on my list.
So I listened to a pair of 8361 two days ago, before purchasing. They sound big enough for my use and do seem very easy to room adjust. Room adjustment helps a great deal and some further tweeking may sometimes reduce brigthness if the recording has to much highs (not sure how to say it).
I sat aside and even stood up and down and walked around to test the coaxial design's ability to widen the sweet spot (which is something I'm looking for). Although the stereo illusion was perfect in the center, there was a quite a bit left to hear elsewhere.
Tried mono as well, which was surprisingly pleasant, even after having listened to stereo mode (but with no room reajustment though). Since I watched Amirm's video on mono testing, I now try to test every speaker mono too. Some sound very weak or even terrible when playing alone. The 8361A does not.
When the two W371A were brought in to play along with the 8361A, the whole system sounded predictably much much bigger, but not like as if the 8361 alone were ridiculously weak before. I can't fit those subs in my current home and I'm not sure I could even pay for them. But there was some benefit to adding them in of course, perhaps not worth as much as 18 more k€. Not sure, but perhaps adding just one cheaper SAM sub such as 7380A could be worth it. Has anyone experienced this?
I cross the 8351bs to JTR RS2s at 100Hz and it works fantastically. Have yet to hit any sort of output limitation at all at almost 4m listening distance. 8361 should have even more headroom. 7380 won't have the same headroom as the RS2, but it may not matter. I briefly tried 2x 7370s with the 8351bs, but I ran into some output limitations in my rather large room. I'm sure 7380 would be much better though with the 15" woofers.
