- Thread Starter
- #61
I doubt that's a good idea, as far as I noticed, Genelec used to use grills whenever possible to protect their drivers, wo when the Ones don't have it on the mid woofer must have some acoustic reasons to not do so.
Plus the exterior casing have continued the waveguide shaping, adding a cover must affect it somehow
Well in theory, an acoustically transparent fabric should basically be 'invisible' to the sound waves. Usually when a grill causes problems it's not because of the fabric itself, but because of the hard edges of the frame.
I suspect the reason the ones don't have a such a grille is that it would be hard to make it pretty, and Genelec probably assumes its drivers are generally 'tough enough' for most uses.
