I've had m
@amirm I've only had my pair of 8341s for a week but inadvertently came across something in the GLM software that might possibly explain them not being loud enough during the review.
In short, I had a similar experience at first. As a test I set the speakers to -5 dB which was far louder than I could comfortably listen to at length at 1m, but it wasn't blow me away loud. Using fixed volume out of Roon I found myself listening with the GLM volume controller at around -35 to -25 dB typically at 1m. I used them for a few days uncalibrated like this. Then calibrated them which markedly improved the sound but didn't seem to alter the volume level in a noticeable way.
A few days later I tried using the SPL standard volume feature. Afterwards I could barely hear anything until the volume was turned up near 0 dB (and then only faintly) which didn't seem correct. I reverted back to my previous config from the cloud, and a saved config on my desktop, but still could barely get any sound to come out, even when I turned off the SPL standard volume feature.
After several reboots, reloading my previous configuration, and recalibrating them again, suddenly I could get sound out again. Except now they are significantly louder at the same GLM volume level (with everything else in my system being constant). Now I find myself listening at -65 to -55 dB on the GLM volume controller typically with Roon and I can't imagine setting the volume to -5 dB now or it probably would blow me away.
I sent an e-mail to Genelec to try to get to the bottom of it but if the loudness I am getting now is correct, I can only imagine how loud these will get if I set the volume controller to 0 dB now. So I am wondering if perhaps this might explain the perceived lack of loudness during the review?
