I was going to buy the SHD Studio but needed analogue input/output for my non Genelec subwoofers.
You can also get this it was reviewed by WolfX-700 on his site. https://m.aliexpress.com/item/10050...6f1ae966ef5a389c754O.jpg_640x640Q90.jpg_.webpi have a question,
what do people use up-stream with genelecs to stream digital aes/ebu into the speakers?
all i found was raspberry hat from audiophonics that has aes/ebu output... i would not want to hook up a computer all the time, if i would get pair of genelecs
thanks!
The short answer is yes, the bass SPL should be as specified, which is the punch you feel.i have a question...
The woofers are behind for this speakers with holes in top and bottom, but if the woofers are in that position, you gonna '' feel '' the same punchy/energy in the woofers as the tradicionals design? where the woofers point at you
Whats so similar about them?The Presonus has a mic pre built in and is intended as a PA, but it can be polite when gained down to 50% (12 o' clock) on the Line input pot and output pot with nominal +4 dBu input. After these months with 8341 it's fun to listen to these. They are decent PA but really not half bad monitors when you have them set.
Both products are powered 3-way with dual woofers and concentric HF/MF, active crossovers, user adjustable DSP. Name another? I can't think of one.Whats so similar about them?
I meant sound wiseBoth products are powered 3-way with dual woofers and concentric HF/MF, active crossovers, user adjustable DSP. Name another? I can't think of one.
Ex Machina Quasar?Both products are powered 3-way with dual woofers and concentric HF/MF, active crossovers, user adjustable DSP. Name another? I can't think of one.
Time flies away precious
Here is the answer to the sweepstakes to guess the speaker that has more in common than different with lovely Genelec One Series 3-way active loudspeakers.
Thank you for your bids this contest offers no money.
Presonus 328Ai
Maybe try the 8351B insteadMy company picked up a Genelec 8341 to use in our anechoic chamber as a point source for measuring microphones and were very surprised at how early limiting kicked in. And that it kicked in on the tweeter well before the woofer. There seem to be a few other posts in this thread regarding that topic, but thought I would share some measurements to illustrate that the 8341 tweeter can't play full-band content above 90dBSPL//1m. This may be acceptable for music, but our use is for standardized microphone measurements which require sine-wave testing at minimum 94dBSPL//1m. The spec sheet has long term max SPL at 101dB and short term at 118dBSPL, but they're very specific (in the detailed specs, not the "cut sheet") that the content applied is weighted IEC-Noise and SPL output is specified 100Hz-3kHz. While not incorrect, it seems overly restrictive considering this should be a reference-class broadband playback device and even 2-3" full-band drivers can easily hit 94dBSPL//1m above 1kHz.
We're also noting differences on our unit vs other measurements (ASR's data in orange toned down by 2.3dB to adjust for 0.13V drive vs 0.1V drive) which is concerning- especially the LF woofer slope not matching. It looks like LF filters are on or something but we quadruple-checked they are not.
As a third item, we also noted audible port chuffing in the 50-60Hz region above 80 dBSPL//1m. I personally chose to only use the speaker >60Hz but this was noticeable in music clips also.
I wrote to Genelec about these three items and they sent back a nice thoughtful reply but in paraphrased summary, suggested: (a) yes, the tweeter is thermally limited and won't reach 94dBSPL at 1 meter. (b) yes, there's port chuffing but this is hard to avoid and if we're doing critical measurements we may want to block the port and (c) Our anechoic chamber may be to blame for the woofer slope. [my response: yes, possibly. But our chamber is rated at 120Hz cuttoff and -3dB at 100Hz from spec is about 2dB more than we're off for other speakers at that frequency. Time Selective Response (gets a bit hand-wavy including port areas, etc) also seems to indicate this is mostly a speaker-issue not chamber issue].
I'm not going to take additional data as we're returning this speaker, but thought I would share my notes as a word of caution.
