Indeed, but the 8351B does dig a little lower according to specs (32 vs 37 Hz at -6 dB).The Reference 1 with 6.5 inch woofer has as much bass the 8351B that has an 8 inch woofer?
Impressive.
Impressive.
The R3 certainly is better value, but I doubt you can compare it with the Ones. The Reference 1 is what you should use:
* Comparable price (here, 7300€ for the 8351B + GLM kit vs 7500€).
* Not made in a country with dirt cheap labour.
* Probably with more QC (especially seeing the recent shadow flare mounting lottery discovery).
Even then, you have to consider these (ignoring all the performance advantages pertaining to the DSP and room correction package):
* Have to add the price of Dirac, the hardware to run it and the beefy amplifier for a speaker dipping to 3 ohms.
* Not fully coaxial.
* Cabinet is optimized for (a) style, not performance.
* A little bit less flat (Genelec do calibrate every monitor at the factory using internal DSP filters, after all), but still incredible for a passive speaker.
* The Genelec has more LF directivity on its vertical side.
* You get a lot more midrange headroom with the 8351B/8361A, but bass is surprisingly okay with the Ref 1; probably as good as the 8351B.
* IMD is quite worse, even if the 8361A is playing 3 dB louder in those test (100 dB vs 85 dB at 4 m => 97 dB at 1 m).
Sources: Fidely Online and Sound and Recording
Read the sources I've given, the 8361A/8351B (exact same coax driver, crossover frequencies and amplifier power) does around 115~117 dB from 250 to 3 kHz while the Reference 1 is flat at 107~108, both at 3% THD.What do you mean with midrange headroom? i don't see the 8341 playing even loud..., my concern too ( but im not sure ) is genelec go up to 100dB before clipping, but in the specs genelec claim 110dB.
I wouldn't do that in a ported speaker, as everything under the tuning frequency is (potentially dangerous) garbage.My another thinking is, what happen if you rise a little the sub bass from kefs? the kefs go very low without any dsp, i really think you can boost a little the bass from Kefs for gain extension and get lower extension like Genelecs, i really want to see the distortion of kefs vs genelec.
If the distortion are reasonably good you can raise the sub bass, also a guy above confirm the dynamics are better in Legs, without DSP. Which is impressive
Oh i see, but there is no reason for considerer better since the genelec have similar distortion and can't produce more volume in bass/treble, i prefer see the measurements in % instead of dB, is more easy to me. More standard also..Read the sources I've given, the 8361A/8351B (exact same coax driver, crossover frequencies and amplifier power) does around 115~117 dB from 250 to 3 kHz while the Reference 1 is flat at 107~108, both at 3% THD.
This is the average musical spectrum (lacking classical music, though):Oh i see, but there is no reason for considerer better since the genelec have similar distortion and can't produce more volume in bass/treble
Those are almost always done at fixed level, making them useless. Knowing what volume you can reach at fixed distortion is a lot more helpful.I prefer see the measurements in % instead of dB, is more easy to me.
Yes, and I don't recommend you EQ either of those to get more output below the port tuning frequency.But genelec are portered too
More than probably his room, both are very flat in the bass and have the same ported rolloff.and have a nice rise up in sub bass... a user here comment the 8341 feel a over EQ bass vs the ref 1
Yes, and I don't recommend you EQ it to get more output below the port tuning frequency too.This is the average musical spectrum (lacking classical music, though):
[QUOTEBut genelec are portered too
I think he's saying that stereo image on any speaker is not great, and multichannel is always better. I tend to agree, though I'm also really interested in another stereo setup with Bacch dsp. Relatively, they have great imaging. Second best of the speakers I own, and the one that beats it is only slightly better, but doesn't come close to the soundstage width of the 8351s.
Yep, that's what I meant. The soundstage of Genelecs is great, for stereo.
I've never found a study that explicitly included classical but I did find one that included Jazz. It seems like genres vary primarily in bass content and the rest of the spectrum is basically the same slope.
Note: From Spectral Characteristics of Popular Commercial Recordings 1950-2010.
It isn't hard to compare, higher at a frequency is better.Another think, seeying that graph of avg musical spectrum, the mid-bass and sub bass are really important, seeying those measures about ref1 and genelec and r3, who is better for mid and sub bass in term of distortion? sorry but idk how to interpretet correctly the distortion measures in dB, any help please
I did say that the R3 was a lot more value, but that the Ref 1 was the comparable model, on things other than pure performance.Also for example you can buy r3 1799$ + 2 F12G 2000$ + 229$ mini dsp + Purifi VTV 999$, and a few more $ also consider the R7 tower, pretty sure the technnical result would be better than a 8341 alone, it is just really expensive...
Fortunately, only the whole speaker + electronics performance matters.And the electronics inside can't match external, BUT i didn't see any test of inside electronics in active speakers too see if there is any negative impact, but apart of that i don't think genelec are using the most badass amps in term of measurements, or yes?View attachment 113583
i have a question
I saw the measurements from this Genelec at the max output is 100dB?
I didn't notice there is a 8331A, lolWhat do you mean 100dB? The person who posted a 2 meter test a few pages back was testing the 8331a, not the 8341a. The 8331a is specced at 104dB @ 1m, so that's pretty darn near exactly to spec. The 8341A play 6dB louder than that.
It scared the hell out of me when I originally saw that post on Gearslutz lolI'm gonna get a 8331 to test against the 8341.
According to this guy on Gearslutz he says the 8341 and 8351 have a hollow sounding enclosure that reverberates like a drum when you tap it whereas the 8331 does not. Not sure if he's serious but I'll report on the accuracy of that too lmao
https://www.gearslutz.com/board/showpost.php?p=14910002&postcount=453
I usually don’t tap my speakers when listening to music - this definitely improves sound qualityI'm gonna get a 8331 to test against the 8341.
According to this guy on Gearslutz he says the 8341 and 8351 have a hollow sounding enclosure that reverberates like a drum when you tap it whereas the 8331 does not. Not sure if he's serious but I'll report on the accuracy of that too lmao![]()
You don't need to, the drive units are doing it for youI usually don’t tap my speakers when listening to music
What are the results of the test? lolWow, I am going to go tapping my 8331...![]()
