Genelec 8330A+7350A or 8331A? Need help choosing
Moreni
I want to upgrade my workspace with a PC setup.
I currently use a 2.1 speaker system consisting of Edifier S360DB speakers + IsoAcoustics-130 stands.
The current speakers placed (and new speakers\monitors are planned to be placed) approximately ~60-70 cm from the listening position (to the side of the 27" main monitor).
The Genelec monitors will be used for: Davinci Resolve Studio, listening to music on Spotify \ Apple Music \ YouTube, PC games, movies, and etc. Rarely Ableton Live. In general, they will be used for a variety of purposes, not just only for creating music.
I have a limited budget, but I need a high-quality solution that will cover the needs of home professional content creation.
What should I choose in my case: Genelec 8330A (2x) +7350A or just 8331A (2x) without sub? And which sound card for a PC setup is best to choose for these monitors and for my purposes?
The room size is approximately ~16 square meters.
I know that the 8331A will be better for the near field, but I'm afraid that without a subwoofer there will be a lack of low frequencies. Therefore, in my case, it might be better to choose the setup from 8330A (2x) +7350A.
P.S. It is worth noting one more detail. Currently, my speakers (Edifier S360DB) are connected directly to the motherboard (asus z690 extreme) via optical cable. I find it a little annoying that there is constant white noise coming from the tweeters when the sound is turned on at a very low volume or during the first ~5-8 seconds before standby mode. It is very quiet, but I can hear it, and is slightly irritating. Shouldn't there be such a problem with Genelec monitors?
Hi @Moreni! Welcome to ASR.
60cm is right at the limit of what Genelec deems sufficient distance for the 8330's drivers to sum well.
Personally, I'd really rather have a Coax design at that distance.
Have you considered not Genelec? Something like the Orbit 11 or Kali SM-5.
That would relieve any concerns about listening distance and still leave money left over for a Sub. Best of both worlds.
For the Sub, you could consider the Neumann KH750 or iLoud Sub, both of which could effectively replace GLM.
What kind of content are you playing? Do you really need the bass?
Yes, I checked at Genelec official website with recommendations: https://www.genelec.com/correct-monitors
And 8330A, and 8331A – fit good for my desk setup and room \ workspace.
I plan to arrange the speakers as follows (attached the image below).
To be honest, I haven't heard of these models.
The only thing I considered instead of Genelec was KEF. And initially, I was thinking of taking 2x Genelec G Three + F-two sub for my PC setup, but then I started researching the information in more detail and realized that if I was going to spend money on Genelec, it would be better to get a model with calibration capabilities right away.
But in any case, considering the possibility of GLM calibration and the fact that I need a solution that isn't too bulky on my desk, Genelec seems to be the best fit.
Moreover, as I mentioned earlier, I'm not currently involved in music production. By purchasing Genelec with GLM + Elgato Stream Deck (which I already have), I will have a convenient system where I can change pre-calibrated profiles at the touch of a button: for example, for listening to music (where the frequency response will be changed), or a flatter one for creating music (if I want to do that in the future), or a profile with a lot of bass for watching movies or TV shows. It's very convenient.
Considering that I have always used budget Sven 2.1 speakers, then switched to consumer-grade but reasonably good Edifier 2.1 speakers (S360DB model which use an 8-inch subwoofer), I am concerned that when switching to 2x Genelec 8331A without a subwoofer, there may be a lack of low frequencies.
Therefore, I am probably leaning more towards the option Genelec 2x 8330A + 7350A + GLM + Stream Deck = in theory it should be a very good home setup.
The only thing I don't quite understand is whether these professional studio monitors are suitable for simply listening to music. Will I notice an improvement if I switch from the Edifier S360DB? And I also don't quite understand which concretely sound card (DAC) is need to buy for this setup? For example i find this variation: https://www.matrix-digi.com/product/82/X-SPDIF3 - it's will be good?
Also interesting whether Genelec's (8330A and 8331A) will produce a quiet noise (like "white noise") from the tweeters (as Edifier does)? Because right now it's a little annoying to me. And as I understand it, this is not a defect.
Right. My question was what kind of music? If you are listening to string quartets you don't need as much bass as techno/electropop. Rock lovers think the genre has bass, but it really doesn't much.
I listen to different genres, including: rock, alternative, metal, indie, pop, rap, edm, instrumental/orchestral music. Both old and modern/new-school. Also a lot of DJ's, hip-hop, house, minimal. Maybe rarely listen to classical \ jazz. But anyway, is important that virtually any genre sounds good. I need something universal.
Do you listen over about 80db on bass heavy music? If so the 8331a is insufficient.
I don't have a professionally calibrated microphone to measure decibels. But I downloaded an iPhone app that shows about approx ~73-77db in the listening area of my current setup. It turns out that I listen to music at about this volume or quieter.
If you want to produce (mix, master) music with very deep bass I think you should go to a 2.1 system, as a small monitor is unable to reproduce such frequencies.
So you should be able to get 40hz in room at the loudness you need. That's not bass-head levels but it's going to cover a lot of music.
It's a close call. I would do for the 8331a and live with it for a while knowing your are getting better coaxial experience. Add a sub later.
A lot of music have sounds under 40Hz.
... why not 2x Genelec 8330A + 2x Genelec 7350A? (and crossover at 95-100Hz) (same cost like pair of Genelec 8331A)
You don't need 2x 7350a.
"Need"/"don't need" - it depends. If You need higher SPL, You should buy "stronger" set of speakers. 2x7350A + 2x 8330A (crossed at 95Hz) will give lower distortion at higher SPL, than 1xGenelec 7350A + 2x 8330A crossed at 85Hz or better lower than that (when You have one subwoofer You must set lower subwoofer/speakers crossover frequency).
That's not how you choose a crossover.
I have the 8331+7350 and before that I had 8330 on my desktop. The switch to 8331 was definetly an improvement. I have written about this here before more. You should go for it. This is an end game near field setup.
That's how you should choose crossover frequency according to quantity of subwoofers, subwoofers placement, how powerfull are they, how powerfull are subwoofer/s in relation to speakers etc. etc.
Incorrect
So at what crossover frequency will You set for Genelec 8330 x2 + 1x Genelec 7350A?
Depends on the room. This isn't the thread for that.
The entire system should be selected with the room and the listening position in mind. But subwoofer parameters vs satellites parameters should be optimal too.
