Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 7,430
- Likes
- 9,118
@Ilkka Rissanen
When is the 8050C coming out?
Any idea how it would compare to your Thiel 3.7?ASR has really opened my eyes for Genelec. Hopefully one day I will get one too.
Can you hear 20K?The distortion at >10kHz, technically speaking we can't hear the harmonics... right?
No, it is a rather compact package and as I noted, doesn't get extremely loud anyway.
I was listening to it at 3 to 5 feet and it was great. The problem with bass is not just sub-bass though. It clips with higher frequencies at higher volumes.I think pure size wise they are not really large, the bass extension makes it don't need a sub to really fill in the bass as 20-35hz are mostly felt but not heard? but will it be too large a driver in nearfield making the imaging or minimum listening distance quite a lot larger for the use case of real near field listening?
Ic, thanks Amirm, I was just thinking with the 8030C listening around 3 feet away in stereo makes me need a passive amp with -40db to use with lowest +6dBU setting in them, and with a larger woofer I was wondering would longer distance to produce proper imaging.I was listening to it at 3 to 5 feet and it was great. The problem with bass is not just sub-bass though. It clips with higher frequencies at higher volumes.
Can't find out exact quote, but i still remember that KH310 also not very good at high SPL in bass due to sealed design and heavy correction (= power and distortion) applied.should point out that the KH310, a comparable option, had more distortion than the 8050B below 60hz but perhaps it did not visibly complain about playback at that level.
port resonance looks like pretty balanced by the actual FR and low distortion at those FR ranges, but that odd tweeter distortion maybe as said above just harmonics from 27khz breakup, so if I understand correctly when normal DACs don't output signals above like 24khz with proper filtering and mastering files don't contain those details it won't appear IRL?Expected better from Genelec. Port resonance AND those odd distortions?
Do you think it gets loud enough for daily listening with occasional rock out session (not ear piercing in any way)?No, it is a rather compact package and as I noted, doesn't get extremely loud anyway.
Sure.Do you think it gets loud enough for daily listening with occasional rock out session (not ear piercing in any way)?
