Trell
- Joined
- May 13, 2021
- Messages
- 2,752
- Likes
- 3,285
Unfortunately Thomann.de won't ship Genelec products to the USA.
I must have recalled wrongly then as I believed not shipping Genelec products to USA was for monitors only.
I got a piece of granite countertop and put it under the sub. I have a downward facing sub (out of fashion right now). I just figured that it'd be good to reduce floor vibrations whether it was bothering anyone or not. If you find a place that sells those countertop slabs they will usually have lots of "scrap" pieces more than large enough for the area under a sub. You can ask them to cut it to size. I don't think a rubber mat is likely to help a lot.Honestly I am so happy with my setup, but I already have a "problem". My apartment (NYC, pre-war building) has hardwood floors throughout. My wife (2 rooms away) can feel/hear the sub's bass. I think this is in part due to reverberations on the hardwood floor.
Before this becomes a problem for the apartment below me (honestly in my building I hear NOTHING unless the kids in the apartment upstairs play bowling on a hardwood floor, or someone stomps around in high heels), I would like to get a 'rubber mat'.
Before I buy one - any recommendations from the crowd here? Are there specific sub/absorbing mats I should look at to really help with the hardwood floor situation? Or does a simple piece of X work?
That's right. I bought my Genelec stands from Thomann and I'm in the US.
At least once I have had Genelec accessories shipped to the US from Thomann. Other times no luck. Once I found a good price at https://studiocare.com Seems a little random.
You would want to get it a slab a little bigger than the sub itself. As much bigger as convenient but not bigger than you can lift
Aside from bothering people, I have wondered if floor vibrations are significant in adding distortion to bass. Probably not....
Svs has sound isolation get that can be screwed into the sub in place of its current feet. This reduces vibration being transferred to the floor. You can also get sorbothane mats or feet which does a similar thing. However nothing except solid walls can stop bass sounds from creeping to your neighbors apartmentsHonestly I am so happy with my setup, but I already have a "problem". My apartment (NYC, pre-war building) has hardwood floors throughout. My wife (2 rooms away) can feel/hear the sub's bass. I think this is in part due to reverberations on the hardwood floor.
Andrew Zannetos (Genelec USA)
Jun 17, 2021, 19:40 GMT+3
Hi Max,
You likely won't get more than a few dB out of each speaker from their maximum stated SPL specification while high-passed, regardless of the model - you'll likely run into the subwoofer's limit first before you reach any SPL limits from a high-passed monitor.
For what it's worth, I have mine crossed over at 82hz and find them to be way more than loud enough in my small room at 1.4m ear to driver.Thanks for you response. Interesting that they only suggest a few db. I will get in touch and see if they have any additional insights.
This would be a case of looking at the specifications of the speaker (95db).How loud can they get when you're sitting a meter away, without a sub, with bass heavy music (metal, electronic music)?
A bit late, but wanted to mention that the JBL LSR310S seems to be a well regarded choice.So, reading trough all the comments, would the mackie mrs10 be a good companion for the 8030c's? I have no idea if I really need a sub but the 7050 is a big investment I'm not willing to make, especially after reading some specs and comments here.
Besides the obvious brand blasphemy. Will this really deter the signalpath audibly from a balanced id14 out?
It's for critical listening (production/mixing/mastering) from low to upper moderate levels in a (yet) barely treated attic room 2 with slanted ceilings to floor.
I haven't received them yet but I am interested in letting the gennies go easy on the lows with a sub for checking deep low end balance. I know some treatment will be needed for that.
Save up for the 7050 or go with the mrs10? Or any other better choices in that pricerange advised. Looking forward to your take on this.
Best,
Danny
They get plenty loud when you really turn the volume up, the bass is getting more wholesome, while the highs do not get harsh. This is what I can tell from listening to the 8030A's, that are installed at my workplace, where at night shifts, when nobody can complain about some bass heavy UK dance music tracks filling the wing, I have "tested" them a couple of times. No seriously, I have tried to listen to tracks that I do know quite well to understand what they can do.How loud can they get when you're sitting a meter away, without a sub, with bass heavy music (metal, electronic music)?
