Genelec 8030B vs Kali LP-UNF
malp
Hi all,
Need some advice.
I’m choosing a pair of active monitors for a small room, mainly desktop / close nearfield use. I can either get the new Kali LP-UNF for €350, or buy a used/new Genelec 8030B for €650. I want neutral, honest monitors for mixing — I’m not a fan of overly bright HF (Yamaha HS5 felt too forward for me).
Quick context:
  • Small treated bedroom/studio, mostly desk/listening at ~0.6–1 m.
  • Goal: clear, reliable reference for mixing and checking mixes at nearfield levels.
  • Budget: €350 is comfortable; €650 is a stretch but possible if it’s worth it.
Questions:
  1. Which would you pick for a small desktop nearfield and why — Genelec 8030B or Kali LPUNF?
  2. Is the Genelec worth the extra money for accuracy and room behaviour in a small setup, or does the Kali offer the better value?
  3. Any specific placement tips for either on a desk (stands vs isolated pads, toe-in, distance from wall)?
  4. How do each behave in the low end in small/untreated rooms — do they get muddy or are they controllable?
  5. If you’ve compared them head-to-head, what differences should I listen for in critical tests (vocals, acoustic guitar, kick/snare, stereo imaging)?
Thanks real-world impressions, direct comparisons, or links to good listening tests are super appreciated.
1. Genelec
2. I think so
3. I like to use isolation pads that you can angle to aim at you. Genelec cones with it. But not big cost inexpensive foam wedge ones are fine.
4. Kali is muddier but does go lower than 8030. 8030 is cleaner. 8030 will play louder. Build quality the 8030bis in a different league. Kali does have slight bass boost which is often preferable at lower volume
5. We carry both brands at work. I have heard both many times. Never compared these models, head to head. There is a huge price difference, 4x more for the 8030.
No doubt the Kali is one of the best in its price range. I own a pair and have them in my office. It's only competitor is maybe the Adam D3V, which I haven't heard. If it were me, I would definitely go for the 8030.
My only concern would be buying a monitor approximately 10 years old for that price. I would see if the buyer will go lower.
I haven't heard the Kali but I use 8030s in a desktop setup.
They're not too bright despite what you read in Internet comments sometimes. Very balanced and even warm IMO.
I recommend putting them on stands at ear height if you can. The desk bounce was noticeable when they sat on my desk.
Also recommended pointing the tweeter at your ear.
As for low end mud - no different than any other well behaved speaker. You'll want room correction EQ per usual.
I think it's a good purchase at 650 EUR... At least in the US they hold their value very well.
Hi all,
Need some advice.
Quick context:
Questions:
hello,
If i may ask, Any reason Kali IN-5 is not on the list? new ones cost 650 euros in eu. Do you think they will be too "boomy" for your room, or too big for your desktop?
hello,
Hi. Because I have a very small place, with a tiny desk, so I need a pair of small size speakers. I already purchased a pair of 8030C, waiting for them to arrive :)
