Djangojanner
- Joined
- Jul 13, 2021
- Messages
- 1
- Likes
- 0
Hi there , my current desktop set up is : Genelec 8020 B active monitors connected by XLR lynx cables to a Gustard X16 . I also have a topping L30 headphone amp / pre which is connected to the Gustards rca out . I don't really want to keep unplugging cables but the output from the dac straight into the genelecs is pretty hot . To give a pleasant moderate volume while working i'm using only 25% volume on the genelecs and still - 27 db on the dac volume. If i set speaker volumes to 50% your looking at somewhere around - 50db on the dac.
Which is going to be the best way to regulate the volume ? There's no way i can set the dac volume output to max , i'm assuming there is a certain power output sweet spot on the genelecs where they work best .
Previously i used XLR from genelecs to rca on the topping L30 and used the pre setting to regulate the volume , but that means unplugging every time i used headphones and i figured running speakers straight to the dac would be preferable : fewer devices in the chain the better.
Is it acceptable to run the Gustard at low outputs from -25 to -50 db or should i be getting a passive XLR Attenuator volume control ? I'm really only interested in audible differences rather than just measured differences that i won't be able to hear.
