I do not see any sense in this 8010 vs 8020 comparison. What 8010s and 8020s suffer from equally is lack of sub bass, which can only be fixed by a sub. SPL of the 8010s is much higher than you would ever need at the desktop listening distance. 8030s can pass as a sort of full range system, but they are a bit large for a desk.
Not agree, It sounds reasonable but the fact is that 8020 is one of the best sellers at Thomann.
Many people, as me for example, they want a desktop setup that can easily transform in a home setup if wanted.
Of course, in small rooms, cannot fill a 20x20 feet living room with those littles.
My solution to a quick transformation of my Office (physiotherapist) when I have no patients and want to listen jazz or rock, or even classical at 1.5 - 2 meters:
Take BOTH speakers in one single movement, place them on hidden floorstands I have in a closet, and connect the sub. Set the preloaded room correction in my WiiM and enjoy
Even more, I'm considering to try a WiiM Sub Pro, the range of bass I need in my office only goes to 40 Hz with some authority at 80 dB @ 1m.
Cannot do that with 8010s.
Reading posts and comments at Thomann, It seems Genelec 8010 to 8030 covers the following uses:
8010: desktop with laptop, travel setups, small cabins in studio.
8020: desktop with PC, home setup or behind-desktop in small rooms.
8030: desktop with PC, home setup in medium sized rooms.
All three NEED a sub: don't use 8030 as full setup, the 50-60 Hz range is not at the level of the rest of the speakers. They do the job, that's all.
