Genelec 8010A Powered Studio Monitor Review
Without meaning to put anyone off, I think many will reconsider their standards after reading this ^^
It's ridiculous to own a $4000-$5000 Genelec and play it in an unsuitable, untreated room... (wtf) => you'll hear the walls (phantom speakers). [reflections]
Even worse, those who benefit from SVS subwoofers and the like...
(make things worse)
(I went through the same thing in the past (when I was starting out), and lost a lot of money ^^)
Genelec 8010/8020/8030 => good standard in a small room
I preferred the 8010 for office use, but the 8030 is also excellent; it's just that in an untreated room, the bass response of the 8010 will be less problematic.
And no, I'm not a marketing salesman... just a passionate trained in the field. In the past, I was manipulated by marketing... since then I've learned a lot... and since I really enjoy sharing my knowledge, it's with pleasure that I wanted to shed some light on certain things from a solid foundation.
There's still a long way to go... I don't have expertise in Amir's speaker testing, for example. I have no ego or anything like that; I'm just talking about what I know. Acoustics are important in a room when dealing with bass frequencies as a priority => first priority => number one enemies in a room. You're free to do as you please, but you'll never hear the true sound of your speakers, some of which are quite expensive.
If you don't have the means or the desire to treat your room, the Geneelc 8010/8020/30 or small speakers, for example, in a bare room, will give superb results.
I owned the JBL 308 mkII and they are very powerful with very deep bass, which is bad in an untreated room.
I now have the Genelec 8010 and the sound is more consistent for my room and office use. A speaker that goes into the infrasonic range requires serious treatment in the corners of the room, at a minimum with large absorbers or bass trap membranes.
(This isn't marketing, just so you know)
I build my own bass traps, it's not difficult => you create a frame for the panel (then you put thick mineral wool inside (20cm thick)) [REFLEXION FREE ZONE aka RFZ]. For the corners of the room where the bass is loudest, you can build "superchunks" (look them up on Google). Just a bit of amateur DIY(40cm thick minimum).
I remind you, maximum "air gap" = thickness of the mineral wool
PS: Remember to protect the fiberglass insulation with a vapor barrier on top.
Happy DIYing and happy listening.
I would have advised you on which type of fiberglass insulation to use, but I know that's just marketing. I've said enough; I'll leave that part (research) to you.
We are aware of off axis response. It's always measured. Off axis response can sound good if it's an early reflection.
What about the 7040 subwoofers?
I use a 7040 with the 8010s on my office desktop. Works well in this config, but to be honest, I've never attempted to energise the whole room with it.
Back home, I have a 7050B (with my old 1029s), which is still going strong. Maybe a used 7050/7060 would do the trick?
Mani.
Mani.
Agree, 7040 was designed for a very close position under a desktop or in a very small room.
But notice than @Xaviedie is not wanting a full pressurized room, maybe the 7040 will works for his office.
Personally I think 70XX Genelec’s sub are overpriced for what they do, my recommendation would be more on the SVS or Kali side.
73XX line is another thing, but prices get higher.
They stopped manufacturing them, except the 7050 I think. That may be an indication of the relative popularity. I agree they are wildly overpriced.
In Thomann, the 7040 is still in the top 10 best selling. Is in the 9th position, just below the 7350 in the 8th.
For a single 6.5 inch cone, is noticeable to reach -6 dB @ 30 Hz, -3 dB @ 33 Hz with 50 watts and peaking 100 dB SPL.
I think one of the reasons of its popularity is the increased little home studios, where people use their bedrooms to mix and edit. For such a use, 8010 / 8020 and 7040 are in the top mini-setup.
Indeed, I listen to them in a setup: small room of 15 square meters / office (nearby field):
7040 vs. 7050.. (by thoman)
Genelec 7040:
6.5" Active Subwoofer
Power: 50 Watts
Frequency Response: 30 - 90 Hz (-6 dB), 33 - 85 Hz (±3 dB)
Max SPL: 100 dB
2 x XLR Inputs
2 x XLR Outputs
Dimensions: 410 x 350 x 205 mm (H x W x D)
Weight: 11.3 kg
Genelec 7050:
8" Active Subwoofer
Suitable for 2.1 to 5.1 configurations
130 Watt Class D Power Amplifier
Frequency Response: 24 - 85 Hz (-6 dB), 24 - 120 Hz (LFE)
Max SPL: 103 dB SPL/1 m (short duration in a half-space) (Average 30-85 Hz)
Speaker: 205 mm chassis
Bass management with integrated filtering for connected speakers
Switchable filters for room acoustics adaptation
Connections: 5 x XLR line inputs
XLR LFE input
5 x XLR line outputs
Foot control connection: 6.3 mm jack for bypass function
Dimensions (H x W x D): 410 x 350 x 319 mm
Weight: 17.3 kg
Dear All:
i bought the Genelec G One speakers which are the same as the 8010A. i also bought the F One subwoofer.
this 2.1 system is for my desktop PC's use. my desktop PC has a 3.5mm headphones output, and several USB-C ports. it is an enterprise line of desktop PCs made by HP.
in terms of how to connect my desktop PC to the F One subwoofer, there 1 analog method and 2 digital methods:
Analog Method:
3.5mm to RCA L and RCA R cable, going from the PC's 3.5mm headphones output jack, to the F One subwoofer's analog L and R inputs.
2 Digital Methods: (1) USB-C cable to SPDIF/Toslink, going from any USB-C port on my PC to the SPDIF Toslink input port on the F One.
(2) USB-C cable to coax digital cable, going from any USB-C port on my PC to the coax digital input port on the F One.
may i ask what method is most desirable and the pros and cons please?
for the digital method (1) above, this is the cable i was thinking of using:
for the analog method, i am using this cable currently:
thank you so much in advance!
Dear All:
Analog Method:
USB-C to Toslink would be my choice.
For one because Toslink effectively prevents noise from being transmitted from the PC to your sound system, as it is galvanically isolated by nature.
And for the other because the F One's presence of a remote control with volume likely means that the analog input is first being digitized inside the subwoofer, and so feeding the sub digitally not only bypasses the PC's basic internal DAC, but also the F One's analog to digital converter.
You just have two fewer signal conversions in your chain.
For USB-C to Toslink, consider the SMSL PO100 2024.
@Miguelón
thank you kindly for your comment above. i see that you have many Genelec products and i'm a newbie to Genelec, as my main system doesn't have Genelec speakers in it.
i now have the G Ones and one F One set up with my desktop PC. i just got this yesterday and am using (to start) the 3.5mm to RCA to connect from my PC's headphones output to the F One.
i believe @staticV3's comment meant to say that by connecting in my CURRENT fashion, i am using my PC's inferior DA converter, as well as its internal amplifier/gain section to power the headphones jack which i am using as my input to connect to my F One. his comment about F One's analog to digital converter is likely a typo, i believe.
what i can't understand is why @staticV3 wrote in another related thread that USB-C has an UPPER LIMIT of 48 kHz!! as such, the highest/best choice for me would be to select 24/48 kHz, and even 24/96 kHz would not work as USB-C (according to him), cannot transmit above 48 kHz.
please see these two screenshots:
below is the part of the F One's manual that states the options available to choose from in terms of output of the SMSL PO100 2024:
you see the part where it says 24 bits is max word length, and 96 kHz is the maximum sample rate.
however, on another of his posts, he said USB-C's limit is only 48 kHz, so i cannot select more than 48 kHz, so that's the best i can do from all the choices you see in the above screenshot of what SMSL displays as options for their PO100 2024.
i don't understand why USB-C has such a limit. i've always thought USB-C has a wider limit?
I’m not sure that the F One or F Two have an analog to digital converter.
All outputs are analog, and dip switches look analog also, or maybe not.
I cannot find any mention to an internal DSP on the Genelec website.
True, I just went off the fact that the F One comes with an IR Remote for volume control, and that an internally digital signal would be the easiest way to implement that.
On second thought though, it is possible that Genelec are using a volume control chip like the NJW1195A for a fully analog signal chain and using Digital in simply substitutes OP's PC DAC for the Genelec's built-in DAC.
But even if that's what Genelec are doing, Toslink still seems like the superior choice here.
I would also try the Tosslink path suggested by StaticV3, I haven’t his expertise on the matter, but PCs headphone outputs tend to have more interferences from the PC itself. Or leaking.
Apart from that, I can add another argument: if you want to use wired headphones you shouldn’t unplug the F One cable.
If the mentioned cable is not expensive, you can also try both pathways and give us a feedback, useful to other users.
When I had the F Two, which I returned because too expensive for its capabilities, It was directly connected by RCA to my WiiM Ultra at its analog sub output. So I can’t add any feedback on those 2 different pathways, it seems way more useful the analog to have control of the delay and synchronization of the sub - monitors.
@staticV3
Hello! thank you for your advice/suggestion.
you had previously wrote "For USB-C to Toslink, consider the SMSL PO100 2024."
that's what i ordered.
may i please ask, with so many other similar-sounding models from SMSL and others, are there even better options to order please? or is the SMSL PO100 2024 as good as these things get?
fyi: on the F One's manual, it says specifically that
"24 bits is max word length, and 96 kHz is the maximum sample rate."
so it seems like Genelec is using an older and less high end DAC than one would have hoped for, right?
i'm asking in case there are superior model or brands or other options that might be even better than the SMSL PO100 2024.
i am very weak on these devices as i've never ever encountered one before. this is my first time using these interfaces.
thank you again in advance.
You are going through the Genelec DAC either way. Unavoidable
I understand that.
I'm merely asking if there's a superior interface device than the one I bought.
The PO100 2024 is bit-exact. It can't get any better.
No, absolutely not.
Max word length and sample rate have little to nothing to do with DAC quality.
Thank you for your reply.
May I ask if you might be able to elaborate this a little bit please? Why, may I ask, would word length and bitrate not have anything to do with the dac's quality please?
Thank you.
Thank you.
What makes a DAC good are its analog properties. This includes:
-Frequency response
-Nyquist filter response
-Noise and distortion
-Jitter
Yes the DAC needs to support at least 44.1 (better 48kHz) to cover the full range of human hearing, and 24bit to satisfy even the most demanding applications WRT SNR, but after that it no longer matters.
So whether a DAC maxes out at 24bit 48kHz or 32bit 768kHz no longer has any bearing on its ability to resolve music.
24/48 is already a fully transparent container for digital music. Beyond that, it's the DAC's analog performance characteristics that determine how well it can resolve music.
@staticV3 et al:
thank you for all your help. the PO100 2024 arrived and i connected it to the F One subwoofer via a Toslink spdif cable from Amazon with some 64,000 reviews. Haha.
it is significantly better than my former 3.5mm headphones output from my pc connected to the F One's analog inputs.
i am using the maximum the F One allows: 24/96kHz. its manual says that's the top limit.
as @staticV3 said 24/48kHz is plenty, so the 96kHz is "bonus".
i'm hoping that Genelec didn't cheap out and select an inferior DAC chip for the F One, particularly since the F One seems so overpriced (to me). i'm ok with the G Ones' pricing. i think $400 each is fair for their quality. but the $1,050 for the G One is way overpriced imho. on the other hand, i want to be sure the 2.1 system sounds cohesive, so i took a leap of faith and bought it anyway, though cringing at the price of the subwoofer.
one ergonomic criticism: the adjustment for the subwoofer's level is on the bottom of the F One sub. very inconvenient to make adjustments. since they already have a remote control, why not allow the user to adjust the sub's level via the remote? it really is a hassle to turn the thing over to make small adjustments, especially with all the cables connected.
