It's normal, few people talk about it even though it's very important. You should know that the listener should never position themselves in the center of the room, across its entire length and width, because there's an audio "hole" or "dip" (due to reflections canceling each other out). These are the areas where the sound is weakest (in decibels) (with loss of audio information, etc.).Exactly what I was thinking lately! Very puzzling.
But when I sit next to my wall, the 8030C has too much bass. Whereas when I sit in the middle of the room, it sounds so tiny and dull! Perhaps it is a beginning of explaination...
This is bizarre… with a good equalization, you can compensate for the room modes that obviously bother you in around 50 - 70 Hz (otherwise it will covered by the 8010 and uncovered by the 8030).It's normal, few people talk about it even though it's very important. You should know that the listener should never position themselves in the center of the room, across its entire length and width, because there's an audio "hole" or "dip" (due to reflections canceling each other out). These are the areas where the sound is weakest (in decibels) (with loss of audio information, etc.).
It's also forbidden to position yourself less than 2-3 meters from the back wall, because the bass energy passing through the walls ends up in the back corners of the room. It's at the back of the room that you get that muddy or dirty bass; it's an area to avoid if possible. It's not for nothing that the back corners of a room are the areas where wideband bass traps should be installed (it's mandatory).
I've read your posts on the forum, and it's not right to judge a speaker based on poor speaker placement without knowing your room (layout), wall impedance, or even worse, if you have no acoustic treatment at all.
The advantage of the Genelec 8010 is that they barely reach into the infrasonic range, which is a good thing. They'll excite the left and right side walls much less, and they'll limit the damage caused by having too much sound absorption. Better yet, even without acoustic treatment, you'll perceive the direct sound better.
I owned the 8030C, which I sold in a hurry, not because of its performance; it was superb. Regarding my analysis below, I acquired the 8010s, and they are just as superb as my old 8030s were in my 15 square meter room. The sound is cleaner; I listen from 1.7 meters away, and it's night and day. I really don't perceive any regression compared to the 8030s; they are more precise... because there's less bass, which is beneficial! Admittedly, they don't go as low, but to the ear, it's "wtf," you wouldn't have guessed, and the bass, even without acoustics, is cleaner considering its size.
Its small size (laws of physics) means that the volume level will be limited for listening in large rooms or when listening from a great distance. For office use, they are what I would recommend over the 8030s, for example, if you have a smaller budget.
For the bass, I plan to get a subwoofer soon. Any suggestions?
Listening without a subwoofer is possible with the Genlec 8010s in an office setting, and it's simply stunning. Before getting them, I sold some JBL 308MKIIs with their large drivers and heavy bass, which were too powerful for my room (which isn't yet acoustically treated). They were too energetic, with too much sound coming from the left, right, front, and back walls, and the fact that there were two powerful speakers on either side. All of this is resolved with the Genlec 8010s. The sound is less aggressive, and the volume is perfect in a small office room. The speakers aren't placed directly on my desk (which is best avoided due to direct reflections off the desk edges). They're on tall stands in front of the desk and spaced about 1.8 meters apart. I'm 1.7 meters away from each of them.
It all depends on your room layout. The closer you are to the walls, the more bass you'll win level decibel (coloring). The speakers themselves should be close to the walls behind them with a panel no more than 10 cm thick to absorb SBIR (short, deep, inflected sound). The further the speakers are from the wall behind them, the more comb filtering (SBIR) will occur in the bass frequencies, requiring very thick panels. So, it's better to use a thin absorbent panel to correct the comb filtering in the treble; it's easier to correct while still maintaining a sense of space in the room.Just got a pair of 8010As and when sitting at my desk I feel they can get very loud... which stays true even if I'm 2m away from the desk.
What about the 7040 subwoofers?Yes, they show their limits on some Kanye West tunes with some deep bass, but in a nice way (no distortion or anything unpleasant as described in the review). It still sounds great. Same for Aphex Twin, Apoptygma Berzerk, Burial and some other electronic stuff.
They're perfect for listening to Metallica, The White Stripes, King Crimson, Sting and similar stuff.
I can also push them while tweaking my Yamaha MODX synthesizer, which is expected.
I'll probably get the 7040 sub, but very happy with the performance atm for what they are.
A subwoofer is essential for any speaker; it's the acoustics that should be your primary concern. The size of the speakers depends on your listening distance, that's all. For desktop use, smaller sizes are more suitable.Maybe move monitors closer to wall?
For a size have plenty amount of bass, especialy for desktop aplications. Its missing lower bass, thats for sure.
False, don't believe the hype… Equalization is only effective if the room is properly acoustically treated!This is bizarre… with a good equalization, you can compensate for the room modes that obviously bother you in around 50 - 70 Hz (otherwise it will covered by the 8010 and uncovered by the 8030).
Nothing particular happens with the size of the woofers, the lows disperse spherically and behave more as standing waves no matter the source.
The mid-highs and highs of the 8030C are even clearer than 8010, look at the spinorama, apart that I had all 8010, 8020 and 8030 in my room.
Are you measuring your room? Just a couple of modes corrected and the monitors will shine…
And of course, all music merits at least covering until 40 Hz, perhaps 30 but 40 is for sure!
How much are you willing to spend?Help good Subwoofer for my 8010 ?
I don’t know that marketing you’re talking about… also I’m not saying at all the bigger the better.Wrong, don't believe the marketing hype... EQ is only effective when the room is properly treated!
Yes, bass waves from 120Hz onwards are multidirectional and become increasingly wide... 2.14 meters (wave length) at 20Hz, EQ isn't going to fix that... it's acoustic treatment. Unfortunately, in a small 20 square meter room, it's impossible to completely eliminate the problems of infrasound (bass); there's no magic bullet. But you can improve or limit the damage with wideband bass traps in the corners (not panels, but large cushions made of fiberglass insulation => you also need to know which type of fiberglass to buy). EQ is the icing on the cake to improve things if, despite the treatment, you still have a slight problem.
Acoustic treatment is essential in a the room. In a bare room, bass is unplayable, even more so in small rooms.
So, reading some people's comments about wanting large speakers only to end up listening to the walls is a bad investment. The Genelec 8010s are 100% suitable for office use. Even without acoustic treatment or EQ, the sound is pleasant in my home, with the volume perfectly optimized for my 15-square-meter room.
Mine is very recommended to small rooms: Kali WS 6.2Help good Subwoofer for my 8010 ?
How is EQ marketing hype when it can be done entirely for free?Wrong, don't believe the marketing hype... EQ is only effective when the room is properly treated!
ThanksMine is very recommended to small rooms: Kali WS 6.2
Genelec 7040A was recommended here as it makes a good combo with 8010 and is also adequate to small rooms.
I understand that if it's for distant use, the 8030 would be more suitable.I don’t know that marketing you’re talking about… also I’m not saying at all the bigger the better.
8030C is perfectly suited for a room as yours, is a near field 5 inch monitor.
The variable you’re not talking is SPL. You probably listen music at very low volume and with the speakers on your desk. Which is the disposition ment by Genelec for 8010s.
I listen my 8030C in a similar room (around 5 meters per 4, but with some reflective semi-walls. Virtually is 5 x 3 meters). But they are placed on floor stands, and I listen from 2.5 meters. No carpets or curtains.
Is not simply a question of volume and cone surface. 8010 were totally insufficient for my room, having same dimensions than yours.
Your post seems containing more marketing than the mentioned “marketing hype”.I understand that if it's for distant use, the 8030 would be more suitable.
The closer you are to the speaker, the smaller its size should be.
The 8030 is also good for office use, but the 8010 in this configuration is also good. (I owned the 8030, which seriously requires acoustic treatment. They have bass = reflection => problem. The 8010 too, but it's cleaner in a bare room, to sum it up.)
Verdict: Treat the bass in your rooms, especially in the rear corners, with Porous absorber fiberglass insulation (do your research). Once that's done, get a subwoofer and address any early reflections.
Don't forget the speaker and listener placement described above. With REW and a subwoofer, you'll be all set to fully enjoy your speakers,
Verdict: Treat the bass in your rooms, especially in the rear corners, with suitable (thick) fiberglass insulation (do your research). Once that's done, get a subwoofer and address any early reflections.
(Or you can ignore all of this and continue to believe you're just listening to your speakers and giving false opinions ^^ good luck)
(Speakers wolrd isn't all sunshine and rainbows! )
Neutral speakers are no longer neutral in an untreated room. His request for investment
Headphones or earphones solve all these problems .. but limited
Wavelength incorrectAcoustic treatment is also limited, as you mentioned 20 - 30 Hz have wavelengths on the order of 1.5 - 2 meters. Even 60 Hz requires very thick treatment to be absorbed.
Oops, I made an accidental mistake, thanks to Ellebob for correcting me.Your post seems containing more marketing than the mentioned “marketing hype”.
Most of us we have our setups in places where we cannot treat acoustically, other than a few carpets. I have 2 exploration foldable tables in the corners of my office, for example.
We don’t have to need a perfectly isolated room, or reducing the range of the spectrum we listen (in general).
My setup sounds “enough good for my budget and physical possibilities of my room”. That’s all I can do actually.
In the future, if I move to a bigger place and have more freedom in decoration, I will install panels to main reflections (around 600 - 700 Hz, 300 Hz in my actual room), some bass traps on the corners and a celling panel also.
For instance, I enjoy a lot !
You can attenuate the sound (boost absorb) with wideband bass traps that have an air gap in the corners to improve absorption (the air gap shouldn't be greater than the thickness of your porous absorber). There are also membrane bass traps designed for very low frequencies. But it's not precise from one product to another. GIK Acoustik is reputable (you can trust them), you can also build your own, it just requires a good tutorial (not easy)Wavelength incorrect
20hz = ~17.1 meters
30hz =. ~11.4 meters
60hz = ~5.7 meters
Bass absorption needs to be very thick for lower frequencies to be effective. Most bass traps not effective at lower bass frequencies.
