To be clear, which speakers were you actually comparing? Cause the picture you posted is for Gelenec speakers, not the Neumann KH420. Also the Geithain 944K is a much smaller speaker than the 901K, and will not have the same bass response.
I agree — Neumanns do have a punchy bass. However, to my ears, an acoustic drum sounds more natural on the Geithains than on the Neumanns (I can only compare them to the KH150s with a sub).Overall, I preferred the sound of the Neumanns. I found the bass to be much more precise, and imaging / phantom center localization was excellent. Everything felt tight and controlled.
Depending on your mood, you could put the Geithains on top of the Neumanns or the other way around. This way, you wouldn’t use any more space than a single pair of speakers would...If I had more space, I’d keep both. I could even afford to — it’s just the space I’m missing. Very nerdy, I know.![]()
Haha - "zwei Fliegen mit einer Klappe" as we Germans would say.Depending on your mood, you could put the Geithains on top of the Neumanns or the other way around. This way, you wouldn’t use any more space than a single pair of speakers would...![]()
Same situation here. I’d like to have multiple pairs but don’t have the space. Not so motivated to move speakers around given weight/hassle.If I had more space, I’d keep both. I could even afford to — it’s just the space I’m missing. Very nerdy, I know.![]()
Now, having listened to some of these loudspeakers myself - the ME901K, KH420 and 8C - I can understand your personal ranking much better and would agree that the larger monitors are in another league than the 8CIt’s a speaker no one’s heard yet with a 6” woofer. Why bring it up vs large Neumann and Geithain speakers? Same for the D&D mentioned several times in this thread as well: speakers with “perfect measurements” are often mentioned together as if they were perfectly interchangeable, but they are not. I’ve heard the D&D and the Neumanns in the same room at the dealer, and then two of the bigger Geithains (901 and 921) at another dealer. For me, 901 > 921 > 420 >>> 8C. In fact, the 8C was a real disappointment, the only thing going for it are the living room-friendly looks.
I think in the end we would require a scientifically perfomed ABX blind test like those done by Harman to provide a final statement. Unfortunately this might never happen.I had the 944s here i would have liked the 901s,( only one dem pair in the Uk apparently) the D&D8C. were better in every single metric than the 944.
Agree regarding the Mangers! They sound terrible.The 944k are around the same price, getting towards £13l per pair over here. I spent some hours listening to the ( one pair of UK demo 901s ) at KMR they were solid enough, without directly comparing them in your own space difficult to really know.
The 944k didn’t have the clarity, extended bass or adjustability of the 8Cs.
I think this was them next to some Mangers that also didn’t last long.View attachment 516940
How are you getting on with the 901k’s now?Hello all,
Dr Dredd reporting in!
The MEG RL901K in Satin Walnut arrived a little over a week ago. They took about 15 weeks to arrive. They were built to order so this is fair to me.
They arrived in flawless condition. Well packaged with great care.
I plan on posting better pictures as well as any in room measurements i have taken this far soon.
I haven’t fully dived into measurements for final listening position and speaker placement (gonna need to phone a friend, 100lbs each!) but i have them in the room in an equilateral triangle on 4 isopuck76 and custom stands i built out of mdf filled with sand and sealed with silicone.
*beginning of subjective experience
I haven’t gotten to measure simply because i have been busy listening… pretty much non-stop.
I will keep the superlative's to a minimum.
I have been going through my favorite records and all of the top 40s from the last 6 decades. It has become very apparent which records were diligently recorded, mixed and mastered.
Some songs have become almost unlistenable because of the balance, noise, or distortion. They have given me a new level of connection to the music. The great songs sound unreal, like no speaker is there, makes you want to dance.. etc.
can clearly hear a 1db change, 0.5db change, clear as day. Compressors eq very apparent.
Bass for days and very deep. No headroom issues whatsoever (regardless of amp power). The walls start shaking before i get to noticeable distortion.
Couldn’t be happier with the purchase.
*end of subjective experience
I am currently using a combination of rew and open sound meter to take measurements with a omni measurement microphone (calibrated with calibration file included with mic).
My knowledge is limited to reading phase data, tonal balance and waterfall data. If you guys know of any resources on how to take and include relevant data thoroughly (as well as understand) I would be most delighted to provide.
The room is a modified garage. Airtight but has its flaws. There is some sound leakages and it is not perfectly symmetrical, thinner walls. The treatment inside helps substantially. The walls are covered 2/3 surface area by 3” rockwool panels. The front corners have 6” rockwool infront of 9” pink fluffy. The first reflection points LR and cloud above have the same.
I forget exact measurements but something like 18’x23’x9’ WxLxH.
I plan on moving to a dedicated, permanent and larger space, but this works for now.
Open to any questions!
Here are a couple of quick pics i took on my phone.
Kind Regards,
Dr Dredd
The rl944k is a nearfield. And you compared it with a midfield in a midfield setup, that is like bashing a racing car because it does not work in the sedert like your dirt bike does..The 944k are around the same price, getting towards £13l per pair over here. I spent some hours listening to the ( one pair of UK demo 901s ) at KMR they were solid enough, without directly comparing them in your own space difficult to really know.
If I remember correctly you also did this with the psi a17 years back.
But your opinion is yours to have.
For me Personally the Geithain rl944k is the best nearfield I could find. And i tried a lot. I use them with 13K sub and Benchmark DAC2 HGC.
I owned (among other) Dynaudio, Adam, Genelec, K+H, Neumann, PSI, Barefoot, Kii Three.
I changed speakers every 0 to 2 years and was always aware of the downsides. I used and auditioned many more.
But since I have the Geithains this urgency to improve has vanished. I love how they dissapear and ‘suck’ me right into the music. I purchased them in 2013 and I wouldnt change them for anything.
Around six years ago I owned both Kii three and Geithain. The Kii’s are long gone, and the Geithains are still in my studio.
Last week I purchased an occasion pair of rl906. Use them with an RME ADI-2 PRO FS R. Very Lovely imo. Maybe not quite as clean in the mids and lows as the 944, but definitely the same livelyness and clean unhyped presentation.
There are lots of nice monitor brands, but the only other speaker brand I would consider the same quality level as Geithain is ATC.
