Geekfly Legend 6 TWS
spinrite
My L6 order came in on the weekend and while they are premium priced product. The L6s are made from wood and metal the internal chamber and stem are brass/gold for transporting the audio waves to your ear canals with minimum resistance. Feeding these hi-res audio music from one of many streaming services you forget that iems are wireless and come across like high end campfire multi driver iems. They are truly on another level. Still thoroughly testing them and will come back with more thoughts shortly but for now my mind is blown for how good tws can be when done right. If you're looking for a tws that will last as this long as the technology will last, look no further. Specs listed below...
Brand: GEEKFLY
Model: Legend 6
Chips: QCC3071+HIFI Audio Decoder Amplifier
Soud Dirvers: 2*BA+2*PZT+2*10mm Planar
Sensitivity: 108db
Impedance: 280
Frequency: 20-40000hz
Headphone Power: 55mAh
Charging Case Power: 600mAh
Flagship HIFI TWS
Chips: QCC3071+Hifi Audio Decoder Amplifier
Drivers: 2*BA+2*PZT+2*10mm Planar
Brass cavity, for smooth and transparent natural sound reproduction
Dual-mic CVC HD call noise reduction
APTX-Adaptive HD decoding, Low latency
APP extension, EQ, UI, AMP Gain
Added pictures
Given the low post counts of you both, my schilling sense is tingling. HBB doesn’t seem too impressed with these so far:
Well, high quality materials aside, it doesn't look like the battery is replaceable, so I guess they will last the same amount of time as most TWS IEMs, like 100 charges or so.
The brand promises to replace the battery free of charge for 5 years
Brand: GEEKFLY
Model: Legend 6
Sensitivity: 108db
Impedance: 280
Flagship HIFI TWS
Please tell me where to get the firmware. Is there a way to post it? Thank you very much.
The sound is amazing. Definitely the best TWS.
how it compare vs noble audio prestige or rex 5 tws? im use only z1r and noble rex 5. like both. both shows big soundstage well bass,well treble,natural timbre and tone.
Added pictures
hot it sounds? bassy? how it compare vs noble mystique,noble prestige,noble rex 5? does it has app EQ? im sold my noble mystique and got noble rex5 1DD 3BA 1PL for 500eur. REX 5 has ANC, LDAC. so ,looks that noble sounds better vs aptx on legend6?
same question here.. :) would like to know how would it compare against the Rex 5, considering they costs almost double the price :)
i think rex5 sounds better ,its has LDAC vs aptx only,also im use sony ier-z1r and rex5 near same sounds,but z1r wired has bigger soundstage,yes sony better ones if not best wired iem ever sounding.
