So just got my Ultralite Mk5 and just learning how to use it. Note this is with a Mac.
For that purpose, I've looped SPDIF out to SPDIF in, and am using REW generator and realtime analyser to see what is going on.
This is working and I can generate signals and use the RTA to analyse them. Where I am stuck though is getting better than 16 bit performance, which with a fully digital loopback should be easy. As you can see for the 1kHz sine analysis, I'm only getting 96dB SNR, and ENOB = 16.
I'm assuming there must be something somewhere limiting the input our output (or both) bit depth, but can't find it.
- I can't find any bit depth settings in REW and it's status at the bottom of the page is showing 24 bit in and out.
- Cuemix doesn't seem to have any bit depth settings.
- The Mac Output settings (Midi and Audio) has it set to 32 bit float with no option to change.
