audio2design
- Joined
- Nov 29, 2020
- Messages
- 1,769
- Likes
- 1,830
Copper would be more preferable.
Painted black (or any color) would be best, with black anodized okay. Anything shiny is a failure.
Hi guys,
Did you hear about SiCFETs ? They claim to be better than GaNFETs
"Launched in 2020 the Singularity 3 Class D modules use the newest technology, and are among the best sounding amplifiers in the world. Even in competition with Class A amplifiers. This is leading edge technology. The switching devices in other Class D modules are regular MOSFET's but we use SiCFET's instead, which are about 10 times faster, giving better resolution in the top region, and less switching noise. Due to the latest enhancements in SiCFET technology, these are even significantly faster than the competing GAnFET technolgy in this power class. This may change as technology progresses though."
Is this product UL certified? If it is than those heat sinks are worthless. UL testing usually runs things way above any normal operating temps, and the product has to take it in stride. Unless UL has changed its requirements. In the future they should leave the heatsinks out and save the money. Use more white cementing compound on the inductors, it will anchor them with no problem. Either way, the heat sinks have nothing to do with the sound performance. Everyone knit picking it are just bored. Like me!
Here's the crux of the matter. SUBJECTIVE OBSERVATIONS HAVE NO VALUE WITHOUT CORRELATION TO MEASUREMENTS.
Sounds like BS to me. SiC provides almost no or no benefit at the voltages in audio. Small advantage for the power supply perhaps. The claimed percentage advantages just are not there to be had.
As the junction temp rises, so does the RDSon resistance. And when the RDSon resistance rises, so does the junction temperature. It's a vicious cycle. This is true no matter where the actual FET is living circuit-wise, be it in a SMPS or the final switch of a Class D amp.
Admittedly, I have never designed a Class D amplifier, nor have I ever used a SiC FET in a real-world design... At the same time I can read and understand datasheets and can picture use cases where SiC FET's will make sense.
So, you're right on both of the claims you made against me. Admittedly, I have never designed a Class D amplifier, nor have I ever used a SiC FET in a real-world design... At the same time I can read and understand datasheets and can picture use cases where SiC FET's will make sense.
I'll stand with my original assertion that there is a use case for SiC FET's in high power Class D amplifiers, not in every case, but one could certainly be made.
What power supply voltage is used on the SDS-470c user. The GAN5 uses 34V in a balanced design for a peak of 288 watts at 8 ohms not counting any rail sag. That should be fairly loud with most speakers.I'm have been using a ClassDAudio SDS-470C power amp for years, just got the Mini Gan 5 yesterday, first impression sound is boomier and less sparkling on treble, most probably due to the "balance" output for both bass & treble frequency? Then today I heard it differently, it sounded more transparent and though I thought the bass just could be a bit more than I want, but I like the sound, it still impress me on details, compare to previous SDS amp, but there's one more problem, when I crank the volume near max, for some songs the amp stop the sound, so wonder is it a protection feature to the speakers? This is not happen from the SDS amp though.
aha now it's not happen, suspect is because of my speakers banana metal part touch some other metal part from my monitor, I'm from Malaysia where electric shock can causing death btw haha. Also this amp is not running cool at all, living on 33 level condo without aircon, I feel the massive heat from this amp lol. The song playing is Inva Mula - Lucia Di Lammermoor + The Diva DanceWhat power supply voltage is used on the SDS-470c user. The GAN5 uses 34V in a balanced design for a peak of 288 watts at 8 ohms not counting any rail sag. That should be fairly loud with most speakers.
yeah, I'm posting on behalf of that I'm human and express my feeling subjectively haha. Anyway my further subjective experience after switching back and forth to compare with my previous SDS, I think I like this GAN amp better, my previous SDS has heat issue which solved by removing the top case and putting few coins on the heat sink.The "today I heard it differently" is a perfect illustration of subjective hearing. I am certain the performance of your system wasn't different today.
I hear music differently if I am tired, or stressed, or warm, or cold - or if I've had a drink etc etc. We will also hear a difference if we are listening for one.
State of mind effects what you hear far more than miniscule differences in Amp characteristics. We hear with our brains, not with our ears.
I owned 3 SDS amps, same chip I suppose. Yes I have another NAD master series M22 v2 power amp, Hypex NCore, which I think is neutral with excellent distortion control and more neutral to the sense as pointed by most reviewers. Though overall I prefer smoother sound with just a little bit of warm & fast bass control amp.Thanks for sharing your impressions.
Question : Is The SDS-470c based on the IRS2092 chip ? Do you own other Class D amps to compare ?
@daniboun : It is really difficult to separate passion from listening impressions and to get independent and neutral view. It is not impossible however difficult. I know it from my own experience. At least you need to start with level matched listening within 0.5 dB.
