GALA DAC - New Product, Coming Soon
I guess this is 8-10x value of the parts involved, with no distribution costs, unknown after sales service, etc., I would honour this with 4-5x value the pieces the highest...... Pls go ahead with no USB, love it!!
Are you taking into account the following:
  • Cost of PCB
  • Cost of PCB Assembly
  • Cost of PCB Testing
  • Cost of Enclosure (it is 14 gauge steel)
  • Cost of final assembly
  • Cost of final testing
  • etc.
SNR: 130dB (0dbFS, A-Weighted)
I'm going to call this number now as absolute fantasy, I'm sorry :
That equates to 1.5uV of A weighted noise with respect to your elevated 5V RMS output.
For those that were interested.
I measured it, and when Amir measures it, you will be proved wrong.
The measurement was performed over a bandwidth of 10 - 20kHz, and with the DAC running at 24-bit with 192kHz sampling frequency.
So you feed it a 24 bit 192KHz signal and then brickwall the S/N measurements at 20KHz? How about a decent bandwidth? Let's see what is going on up there.
...I measured it...
What with? I'm interested.
GALA is on the way to @amirm. He should get it on Thursday.
Waiting for this!
I need 8 channels of DA-conversion in my system, so I might be interested in buying your pcb:s only. The cost will be too high for me buying 4pc of your ready made dac, unfortunately.
SPDIF-coax (or preferably AES3) digital input, and balanced analogue output, with SOTA SNR, good low THD, and totally pop-free, are the "only" things I need :) And also, that several dacs does not drift apart in timing (when inputed with the same source/clock )
With all the work and running around trying to get the Indiegogo project running, I never had the time to sit down and properly listen to GALA.
Finally got GALA hooked up to my entertainment center, it sound much better than I could have imagined. It's hooked up to a pair of my own custom designed 25W mono-blocks.
I just received word that GALA will be certified under the Arrow Certification Program.
This is a big advantage for this project as Arrow's engineers have rigorously reviewed all aspects of the design and confirmed that it either meets or exceeds all current industry standards.
For those who are interested here is some more info:
GALA - What's Inside?
Full GALA Specs
  • SNR: 130dB (A-Weighted, 10Hz - 22kHz bandwidth)
  • THD+N: <-108dB (0dbFS)
  • Output Level: 5 Vrms (XLR)
  • Output Impedance: 100 ohm
  • Frequency Response: DC - 22kHz
  • Input: Gold Plated Coaxial S/Pdif
  • Sample Rates: 44.1, 48, 88.2, 96, 176.4 and 192kHz
  • Resolution: 16 and 24 bits
  • Size: 5.5'' x 4.25'' x 2.375''
  • Volume Control: 0 to -80dB, and mute (knob turned fully counter-clockwise)
  • Manufactured in USA
