A lot of measurements here.
Amongst those data:
So, if you push 4V from your DAC, you may attenuate by 23dB, and you'd still get the maximum power if you turn the amp volume fully to the right.
You may do that with the amp volume knob and control your volume through the DAC, or you may set your DAC volume to -23dB, or anything in between.
(I'd personnaly go for the first option.)
You may as well insert your -20dB attenuator.
Balanced input impedance is also measured, by the way :
(It's a shame Music Fidelity doesn't provide proper detailed specifications, by the way. I own an M6PRX myself and that's the same issue.)
Amongst those data:
Input sensitivity (maximum volume, XLR) | 285mVrms |
Input impedance (line input, XLR) | 19.0k ohms |
