Gain in mixed balanced-unblanced environnement, how to not end up with noise through the speakers
Sorry for coming in so late, I haven't been around much here lately.
To recap, what are your AVR --> DME cables like now? While breaking the ground loop between PC and AVR should have been immensely helpful, It would still be best for hot, cold and ground to be separated right at the unbalanced (AVR) output, instead of only at the DME input.
Do you have any better luck with input gain on the DME now? I would think that you'd want a setting of maybe -12 to -15 dB for levels to line up decently. The DME has tons of output, so the t.amp should be set for lowest sensitivity and the level turned down a fair bit (10-12 o'clock).
I've changed some bits lately and have put back my tascam LA-80 in the chain, which did help. RN, the chain is AVR - LA80 - DME goint through adat to DA824 (8 channel ADAT DAC) to t.amp on balanced XLR. With a multipair RCA from the AVR to LA80 and custom XLR from the LA80 to the DME. Breaking the ground loop on the LA80 indeed gave much better results (don't know why i didn't try it before) and indeed, the input gain on the DME is set at -15 to match my AVR's volume readout.
I need to open up the DA824 and mess around with their gain controls (they go up to +24db lol) and see if that would help reduce the gain of the T.AMP even more. Although setting it below 9 o clock on the dial seems to mess with the overall dynamic range of the main outputs, dunno if it's just my hears or an actual side effect of the attenuation, din't have time to measure yet.
