Hello everyone, long time ASR lurker and first time poster here.
Ive been in a bit of a pickle lately with my setup.
I recently went out and bought myself a Yamaha DME24N to replace EQAPO which did my filtering straight on my PC. And so far, tinkering with DME designer it seems like it's doing exactly what i want, which is good.
Now, the thing is, my main source for everything is a PC going through HDMI to a Denon AVR-3808. Which means i only get unblanced pre-outs, and even at -20db volume, the DME isn't even picking up a signal on the front panel indicators. Audio does go through, but it looks completely muted if you only looked at the meters.
I then tried to mess with the input gain control of the DME, and i don't know if mine is broken or if they are really like that, but setting anything other than 10 (default, lowest value, highest is -60) is so noisy that it's unlistenable. With the gain set at -4, the overall volume is correct, but you can totally hear the noise over what's currently going through the speakers.
Speaking of speakers, they're Klipsch Heresy II, driven by a t.amp S75 (that thing too doesn't even light it's signal indicators). So very high sensitivity, and a pretty ill-suited amp (soon to be replaced and relegated for surrounds, which are much less sensitive KEF Q55) which means that the slightest bit of noise goes through and is amplified by the horns.
To summarize for the front channels : PC HDMI (Always max volume) --> AVR (should be the thing that manages volume) --> DME24N (filtering, EQ, TC, Limiters) --> T.amp S75.
Now, i have tried some stuff like using a Tascam LA-80 to convert the -10dbv to +4dbu signal and convert from unbalanced RCA to balanced XLR, but that changed basically nothing and introduced ground loops.
So i'm here in search of tips on how would i go about this the proper way ?
Do i need somthing like a pre-amp on my pre-outs to go in the DME with a much hotter signal ? Do i need a different less noisy amp (which would not solve the issue of noise on the DME inputs ?) or is there a device i don't know about which is made for this exact situation ?
Happy to give out more info and measurments if needed.
TIA for any clues !
TIA for any clues !
