Gaia Isolation anything in this?
Regarding the IsoAcoustics test results, here are some simple "back of the envelope" calculations. Below are the IsoAcoustics GAIA II NRC Canada test results.
The highest peak in the surface velocity with spikes is ~7.8e-6 m/s at ~280 Hz. Using the formula given by Siegfried Linkwitz (source) shown below, we can come up with some estimates of the resulting dB SPL.
Assume (1) the dimensions of the panel that was vibrating is 1.0 m × 0.5 m = area of 0.5 m² (it is assumed that the sound produced would be the same as that from a pulsating sphere of 0.5 m² surface area); and (2) listening distance r = 3.0 m in free space:
Volume velocity U = surface velocity × area = 7.8e-6 × 0.5 = 3.9e-6 m³/s.
Density of air at sea level, 20° C, q = 1.204 kg/m³
Frequency, f = 280 Hz
Distance, r = 3.0
Sound pressure p = U q f /(2 r) = 0.000219 Pa = 20.8 dB SPL.
Thus, from the speaker FR curve as shown in the IsoAcoustics measurements, the SPL produced by the speaker cones was 90 80.5 dB [Edit: Forgot the 3 m listening distance correction, assuming the graph was for r = 1 m] , and the rough estimate of the sound from the panel vibration is 21 dB.
I just visited their room at the Audio Show in Warsaw. The guy in the room was switching between two sets of the same speakers. When he turned on the isolated speakers, it has the very similar effect as I hear when I turn on my DRC or loudness compensation. Is such an effect possible? Or have I been tricked somehow?
This is what the manufacturer measured: no change in frequency response, but a lot less cabinet vibration, which probably is the reduction in IMD show in the 1st post.
Thank you so much for sharing. It is great to see that it does not impact on frequency response but make noticeable difference on IMD (Inter Modulation Distortion?).
I am not personally familiar with IMD and does it impact on human hearing?
I use Isoacoustics Aperta stands on my front and centre speaker. I love the way they look and I doubt they make the sound worse (from briefly skimming the thread it seems FR is unaffected). That's kinda enough for me.
Subjectively I've had less "resonation" from the environment on bassy passages but I had SVS Soundpath Isolation System on the sub and so.. maybe it was down to that. Don't think it was placebo as in certain passages it was quite different.
I am not sure I understand the skepticism towards the NRC Canada tests but, at the same time, I barely understand what they measured. So there's that. :D
It would be nice if more study went into this. But, as far as Isoacoustics products go, aesthetics is enough for me. I try to be as objective as I can in my listening habits but even the eyecandy, sometimes, is worth it. Cheers!
