FXRoute 0.7.41: Auto Sub Optimize for 2.1 setups
FXRoute 0.7.41 adds a new
Auto Sub Optimize feature for 2.1 mode.
The idea is simple: after setting the crossover frequency and a rough subwoofer level/alignment, FXRoute can automatically run a bass-focused delay scan around the current sub_alignment_ms value. The scan range is derived from the selected crossover frequency, so lower crossover points use wider delay steps and higher crossover points use finer steps.
The optimizer measures both
Left+Sub and
Right+Sub for each delay candidate and chooses one shared sub alignment value that works reasonably well for both channels.
If the coarse scan finds a close result, a fine scan is run around the best delay region.
The feature currently adjusts
delay only. It does not automatically change sub gain, polarity, PEQ, target curve, or convolver filters.
The result display shows the applied delay, the overall score, and the individual L/R scores. In my tests this has been useful for quickly finding a plausible sub alignment without manually repeating many sweeps.
Recommended workflow:
- Set up the 2.1 crossover roughly.
- Run Auto Sub Optimize once.
- Create or enable EQ / convolver correction.
- Run Auto Sub Optimize again with the final processing active.
- Verify with a normal 2.1 measurement.
