FXRoute 1.0 Beta – rebuilt from the ground up
I really appreciate your taking the time.
Yes Hz of course brain fart that 8-D
Please keep in mind, I am only talking about using FXRoute as DSP, a passthrough box fed by an 8-port interface, with upstream preamp+switcher in turn feeding various inputs , both analog and digital (CD/LMS) streaming sources. PC as player if ever, only sometimes.
So if I do this:
where it can be avoided, I'd also prefer not to add an unnecessary D/A → analogue processing → A/D round trip.
I think it has nothing to do with FXroute, most likely if I need to upstream only, and tbh my AD/DA conversion will be clean enough I'm not concerned.
So if I do this:
No problem about the Hz brain fart. For a moment I actually thought 50 kHz might still be a semi realistic target you had set yourself. :-)
And yes, I understand your setup now. You basically want source selection and preamp switching upstream and then feed FXRoute through the interface. CD, tape, turntable with phono preamp and similar stereo sources are already covered.
What FXRoute does not have yet is flexible analog channel mapping for multichannel input, which is what you would need to properly try external analog upmixers. I may add that as an option, but I am not fully decided yet since it is probably a fairly niche use case.
An internal upmixer is planned though, and that fits the FXRoute concept much better.
LMS can already be fed digitally into FXRoute through STDIN, completely losslessly, and there are other possible digital paths too.
As for the extra D/A to A/D conversion, I agree that with decent converters it is very unlikely to be audible and perfectly fine. I just personally prefer to avoid unnecessary conversion stages where possible. That is really just a personal preference and not a criticism of your setup.
Good to know about slimproto rendering.
OK, to be clear, setting aside the internal upmixer idea for now, you're saying
your project currently can only accept X input channels (less than 8), so that box must be upstream of any analog upmixing?
Can FXroute accept 7-8ch **digital** inputs?
That is basically just being finished now. FXRoute now has multichannel input mapping, so the earlier limitation around flexible analog multichannel input is going away.
And yes, the same mapping applies to digital input channels. FXRoute does not fundamentally care whether a mapped channel originated from an analog input or a digital one.
For example, with my Scarlett 16i16 the ADAT input channels can be mapped to the corresponding surround roles just like the analog inputs. So a 7/8-channel digital source coming in via ADAT can be used as a multichannel input.
I’m just in the final stages of testing and cleaning up the multichannel mapping before I call that part finished.
btw. STDIN will get a upgrade also.
great stuff, thanks!
I will likely use RME Digiface USB or HDSPe RayDAT to interface your box with the ADAT-based format converters, the input unit as BNC Master over the output units.
RME is always a good choice, i also like the Focusrite Scarlett 18i20 4th Gen if i would need more channels.
only one ADAT.
I have a Yamaha DME64N with four expansion ports, each handling 16ch can be ADAT AES3 or analog as needed. Even AoIP but that gets pricey...
But that's just for format conversion of the output channels, since it has no interface built in.
I've decided to put Qobuz support in FXRoute on hold for the time being and focus on Spotify and TIDAL.
Both services currently have more reliable Linux solutions, with stable and well-functioning clients and integrations.
Unfortunately, the situation with Qobuz has become uncertain. The popular third-party Linux client QBZ was recently shut down following a request from Qobuz. According to Qobuz, streams through the unofficial application were not properly counted, meaning artists were not compensated.
While alternative Qobuz clients already exist, it's unclear whether they might face similar issues in the future.
More background:
For now, I'd rather focus my development efforts on integrations that are reliable and sustainable in the long term.
Spotify and TIDAL will remain supported. I may reconsider Qobuz if the situation changes.
As you know I am rarely if ever using PC-as-player anyway, my interest in FXroute is the pass-through processing from external sources.
So surely however I play my Qobuz stream, so long as that is an input to PipeWire/EasyEffects, surely FXroute's DSP features are just as compatible as with whatever you implement for Spotify and TIDAL, correct?
Yes, absolutely. No need to worry about that. The current Qobuz situation only affects the integrated Qobuz Connect functionality, not FXRoute's DSP processing.
Any external audio source routed through FXRoute can use the same DSP features, regardless of where the audio originates or how you're playing Qobuz.
By the way, EasyEffects is no longer involved. Its functionality has been completely replaced by FXRoute's own DSP engine. You can simply use FXRoute as a DSP processor for external sources, without using any of its built-in streaming integrations.
As for streaming services, Spotify is very well covered. Both the native Spotify desktop application and spotifyd are supported, with spotifyd being particularly stable. TIDAL Connect is also fully integrated and working well.
Qobuz is the only uncertain one at the moment. They've indicated plans for better Linux support, but nothing concrete has been released yet. We'll have to see how that develops.
But again, none of this affects your use case. External audio processing is completely independent of the built-in streaming services.
Thanks. Perhaps more of a marketing angle, I would always include those facts in a positive way, e.g. a chart "here are the ways you CAN feed sources VWXYZ to FXroute" reassure prospect that in reality all are covered.
You do still support PipeWire both in & out? I considered EasyEffects non-mainstream these days but PW is IMO THE audio platform for modern distro's. Also I guess stdin / stdout redirection?
Thanks, you're right. A chart showing all the different ways to get audio into FXRoute would probably be a good idea. I'll see what I can do.
And yes, of course PipeWire is still supported for both input and output. I actually like PipeWire a lot. It's a modern, flexible audio platform and FXRoute makes extensive use of it. What I've replaced is basically the EasyEffects DSP part, which has been a huge improvement for FXRoute.
One thing I've also moved away from is PipeWire's default sample-rate conversion. FXRoute now has its own high-quality SRC solutions, and the results have been really good so far.
Quite a lot has happened on the surround side too. FXRoute now supports proper multichannel playback, including Dolby Digital and DTS, and I've added two stereo upmixers.
The Fast upmixer is a low-latency, matrix-style implementation, somewhat similar in principle to the old Dolby Pro Logic approach. It's particularly useful for TV and anything where latency matters.
The HQ upmixer uses FFT-based frequency-domain processing for better separation of center and surround information. The FFT size is adjustable from 1024 to 8192, so there's a trade-off between processing resolution and latency. Even at the smaller settings, the results are already very good. I've been particularly impressed with how well it works for music.
STDIN is supported as well, including multichannel PCM and custom channel mapping. I'd have to check STDOUT, though.
FXRoute 1.0-beta14 is out!
Quite a lot has changed since beta12, so I thought it was time for another release.
The biggest addition is full multichannel and surround support, including Dolby Digital (AC-3), DTS Core, bass management, and the two stereo upmixers I mentioned earlier.
FXRoute now also has per-speaker-group DSP processing, including PEQ, convolution, A/B presets, and measurement tools. The whole interface has been updated to make this manageable without getting too complicated.
And following up on the earlier discussion about audio sources, here's a quick overview of what you can feed into FXRoute:
SourceHow
Spotify, TIDAL, Qobuz (for now), Internet RadioIntegrated streaming
Desktop applications / system audioPipeWire
Bluetooth devicesBluetooth audio input
External sound cards / audio interfacesPipeWire / Custom Input Mapping
TV / digital audioS/PDIF, including AC-3 and DTS Core
Scripts / external applicationsSTDIN, including multichannel PCM and channel mapping
PipeWire is of course still used for audio I/O. The DSP engine and sample-rate conversion are handled by FXRoute itself, with three selectable SRC quality levels.
There have also been quite a few improvements to measurement, calibration, routing, and general usability.
Beta14 is available now:
GitHub release (including Raspberry Pi 4/5 images):
https://github.com/CobbyCode/fxroute/releases/tag/v1.0-beta14
Ubuntu 26.04 x86_64 ISO:
https://sourceforge.net/projects/fxroute/files/1.0-beta/
And the web demo has also been updated to beta14, so you can explore the new interface, including surround routing and DSP settings, without installing anything:
https://cobbycode.github.io/fxroute/
As always, feedback is welcome!
Phenomenal velocity!
What kind of old-school upmixer are you looking for exactly? If you have a particular matrix/logic approach in mind, that would be useful to know.
I've been happy with analog Schiit SYN, that's my baseline for comparison
See the DSPi project, they not only emulate SYN (maybe OG Hafler too) and Dolby Prologic II
but give user controls for the width, Center voice-register emphasis without affecting L/R, crossfeed effects
On my list to try if opportunity arise:
Lexicon
Auro-3D
'Neo:X Music'
Logic 7 Music with '5 speaker enhance'
DTS Neural:X upmixer
Halo Upmix by NUGEN Audio
Sorry for the brain dump, just food for thought
Thanks for the suggestions! That's quite a list of interesting upmixers.
FXRoute already offers some adjustment options, including separate center and surround levels, and two different upmixing engines.
The HQ upmixer takes a somewhat different approach from traditional matrix-based systems. It uses FFT-based, frequency-selective processing to extract center and surround information rather than relying solely on full-band channel relationships. This allows for more precise separation of different signal components, particularly with complex stereo content.
I'm quite happy with the results so far, especially the stability of dialogue in the center and the extraction of ambient surround information.
As for additional controls, I'm generally a bit cautious about adding too many settings. It's easy to end up with lots of knobs that sound useful in theory but don't necessarily add much in practice. I prefer keeping the interface manageable and focusing on controls that make a meaningful audible difference.
For example, adjusting the center level already gives you some control over vocal presence, even if it's not quite the same as a dedicated frequency-selective presence adjustment.
That said, stereo width and more specific center adjustments are definitely interesting ideas. I'm not opposed to adding them if they prove useful and fit naturally into the existing interface.
Thanks, great news, I must have missed a lot of those (or forgot, old brain)
FXRoute already offers ... two different upmixing engines.
Can you please point to details on these, differences between Fast and HQ etc beyond what you mentioned above?
But meantime, feeding 8ch ADC input from SYN is now well enabled?
Is there an upper limit on either input or output, or DSP (other than host hardware power)?
Sure! Here's a bit more detail on the two upmixers.
Fast is a low-latency adaptive matrix upmixer, somewhat similar in principle to traditional Pro Logic-style processing. It analyses the correlation and balance between the left and right channels. Correlated material is steered towards the center, while diffuse and out-of-phase information is extracted for the surround channels. Hard-panned sounds remain in their respective front channels.
Latency is only about 1.3 ms, making it suitable for applications where low latency matters.
HQ takes a different approach. It uses FFT-based spectral analysis, processing the stereo signal in individual frequency bins rather than treating it as a whole.
This allows it to distinguish between different signal components occurring simultaneously. For example, a centered voice can be extracted into the center speaker while a guitar remains in the left or right front channel and diffuse ambience is distributed to the surrounds.
It also distinguishes between side and rear speakers, directing more diffuse content towards the rears when both pairs are available.
The FFT size is selectable from 1024 to 8192, trading latency for frequency resolution. At 48 kHz, latency ranges from approximately 21 to 171 ms.
Both engines offer Center and Surround controls from 0 to 10. These adjust the strength of the extraction, not simply the output volume. Increasing the Center setting, for example, extracts more correlated material from the front channels.
Neither engine generates an artificial LFE channel. Bass management is handled separately by FXRoute.
And importantly, when actual multichannel audio is detected, the upmixer is automatically bypassed. So it can remain enabled even when switching between stereo and native surround sources.
I'm personally quite happy with the HQ results so far, particularly with dialogue stability and the extraction of ambient surround information. The Fast version is useful when latency matters, not bad at all either.
Regarding your Schiit SYN:
Yes, feeding its analog multichannel outputs into FXRoute through an 8-channel ADC/audio interface is exactly the kind of setup the new Custom Input Mapping feature was designed for.
You can actually explore this in the web demo:
Go to Technical Settings → Source → Input → Custom Mapping…
There you can assign individual capture channels of your audio interface to the eight surround positions (FL, FR, Center, LFE, Side L/R and Rear L/R).
With Surround mode enabled, these channels are routed directly into FXRoute's multichannel DSP engine, bypassing the Dolby/DTS decoder and the stereo upmixers.
You can then apply FXRoute's DSP processing, including PEQ, convolution, room correction, bass management and flexible output routing.
The mapping is device-specific, so the only real requirement is that your ADC/interface exposes the necessary capture channels through PipeWire.
Regarding channel limits:
The native DSP engine currently supports up to 32 input and 32 output channels internally. This is a fixed compile-time capacity, not simply a CPU limitation.
However, that doesn't mean FXRoute currently accepts 32 independent surround programme channels. The supported surround input layout is up to 7.1 (8 discrete channels), whether coming from a multichannel decoder or an external interface through Custom Input Mapping.
The output side is more flexible because FXRoute separates logical speaker channels from physical output routing, including subwoofer and crossover configurations. The actual number of usable outputs depends on the configured layout and the connected audio hardware.
So your proposed 8-channel SYN setup fits within the currently supported architecture.
And if you'd like to experiment with the routing and DSP options first, the updated beta14 web demo should give you a pretty good idea of what's possible without having to install anything.
WOW grateful for your time there, I was just asking for a link 8-D
All that sounds fantastic so far!
Yes I am puzzled by LFE channels, if summed from all the beds, there must often be a mix of "similar but decorrelated" signals in there all mishmashed together.
I prefer each LCR driver stack to have its own clean splitting for co-located MBM/subs
plus (maybe) a separate mono trueSubs group, freely placed to tackle LF room resonances (thinking MSO for that, but happy to test against FXroute)
nit picks:
I would use "encoded multichannel" there, IMO upmixed is a subset of "actual"
> Schiit SYN... FL, FR, Center, LFE, Side L/R and Rear L/R
SYN is only 5-6ch output, I just happen to have 8ch of ADC/interface available on the "master input" node. I plan to use the extra 3ch for giving testing choices on "mono summed elsewhere" inputs. I have an Outlaw ICBM-1 to test, and both SYN and Wiim Ultra have their own mono sub outputs, SYN's "LFE" being very limited though, fixed LPF at 80Hz but perhaps well designed.
Taking Wiim's OG Stereo sum may be cleaner, lots of its own signal tuning available as well, including time domain.
Besides splitting the LCR stacks and that separate group of mono subs, I may never go past 5.1 bed channels, so a 32ch output total maximum is not limiting.
Note that I plan to feed any DSP downstream of SYN at a fixed standard sample rate, and to the extent I have separate host nodes, all their interfacii / DAC / format converters are tied to the BNC Word Clock, ADC input node as Master.
I thus hope to avoid the need for any SRC, unless to cover for (hopefully occasional and fleeting) glitches.
I've been looking for ways to lock the (PTPv2 disciplined over ethernet) hosts' realtime "wall clocks" to the BNC WC "heartbeat" but so far coming up crickets – maybe no point to that?
Again, sorry for the brain dump feel free to ignore these more "out there" topics.
Feedback from anyone is welcome, if OT please append to this thread
rather then derailing here
