NorthSky
- Joined
- Feb 28, 2016
- Messages
- 4,998
- Likes
- 942
No fuse expert here; I found this tube:
Put some blu tack on them ...
Fuses are typically used in three different circuits in an audio component:
1] AC power supply.
2] DC power supply.
3] Audio output of a power amplifier.
The audiophiles that hear these differences never mention which circuit the fuse is in.
Moving on, Bob Cordell is his great book "Designing Audio Power Amplifies" did measure fuse THD in an audio output stage.
It's section '13.11 Fuse, Relay and Connector Distortion' page 268.
Conclusion:
"At 20 Hz, amplifier distortion due to the fuse is calculated to be 0.0033 %."
You're missing my point, fuses in my amp are part of the signal path, not power supply.
They are typically inside the main feedback loop or just supply current to the overall audio circuit which is inside the feedback loop. This means that in a SS amp their small distortion is further cut by one or more orders of magnitude by the inverse feedback.
40 years in the industry and he still knows nothing.
More completely:
At low frequencies the audio signal can heat up and cool down the fuse element within a single cycle, causing the resistance of the fuse to vary as a function of the signal amplitude. This leads to distortion because the attenuation of the fuse resistance against the load impedance changes as a function of signal swing [5]. Fuses are often undersized with respect to the peak audio current they may be called on to pass, recognizing that a smaller fuse will provide relatively more protection and that with normal audio signals, such high currents are brief events much shorter than the time constant of the fuse element. The cold resistance of a 2-A 3AG fuse was measured to be 78 mΩ, while its resistance when passing 2-A DC was 113 mΩ. This represents a 45% increase in fuse resistance.
The distortion of a fuse can be measured by looking at the voltage across the fuse with a sinusoidal signal current passing through it. The fuse under test is put in the ground leg of an 8-Ω load resistor so that the signal voltage across the fuse can be easily analyzed. This technique largely takes the distortion of the driving source out of the picture. Figure 13.4a is a plot of fuse distortion versus frequency when a 2-A fast-blow 3AG fuse is passing a 2-A RMS sine wave signal. As expected, fuse distortion increases dramatically at low frequencies. Signal voltage across the fuse was 250 mV. Amplifier THD (due to the fuse) is calculated by normalizing the fuse distortion voltage to the amplifier output voltage. The resulting amplifier distortion is shown in Figure 13.4b. Amplifier distortion is lower than fuse distortion by a factor of 64 because of the small voltage across the fuse compared to the total signal voltage. At 20 Hz, amplifier distortion due to the fuse is calculated to be 0.0033%.
Other relevant papers:
Amplifier-Loudspeaker Interfacing
Author: Greiner, Richard A.
Affiliation: Department of Electrical Engineering, University of Wisconsin, Madison, WI,
JAES Volume 28 Issue 5 pp. 310-315; May 1980
Publication Date: May 1, 1980
Ideally the fuses used in the output current circuit would be linear resistors as well. However, since Fig. 4. Reproduction of an oscilloscope trace showing that they have to get hot (and melt) to burn out, they are actually out cycle for a fuse with a 20-Hz signal large enough to cause nonlinear elements in the output circuit. If fuses are to be burnout in about 0.8 s.
The substantial change in the slope of the V-I curve shown indicates a large resistance change with heating useful, they must blow out when the system is used at some of the fuse element. specified power level over the maximum desired. Typically, a fuse will increase in resistance to about 3 or 4 times its cold value just short of burnout. At 60% of full load it bursts just short of fuse burnout.
Typical measured modulawill increase to about twice its cold value. A typical fuse tion of a high-frequency signal when pulsed with tone blow-out cycle is shown in Fig. 4. The resistance change bursts that are set at 60% of burnout are shown in Fig. 5. per cycle is clearly evident. The calculations and measure- This figure shows the oscilloscope trace of a 5-kHz signal merits of this section show some possible problems with modulated by 20-Hz tone bursts. The tone bursts have been distortion caused by these changes in the fuse during normal filtered out to show only the 5-kHz modulated signal.
The program reproduction, heating and cooling cycle of the fuse is clearly visible. The Using the simple circuit of Fig. 3, it can be shown that for time constants of typical fuses are such that this heat, and a typical regular speed fuse, of the tubular type, the distortion- consequently resistance, cycling can take place for normal distortion produced could reach the values shown in Table 6. musical beats at low frequencies. To minimize interaction These figures represent intermodulation distortion for any of this type across the frequency spectrum, it would seem frequency when the output circuit is pulsed with power wise to provide separate fuses for each frequency range of a multiway system.
Fast blow fuses are worse than regular ,. fuses since they change temperature 10 times more quickly. " There is no solution to this problem except over fusing or putting inside of a feedback loop. This can be done, of course, by putting the using fuses at all, unless the fuses are included within the fuses in the power supply bus or even within the normal -- feedback loop
Speaker and Headphone Handbook
John Borwick
Third edition pp 293-294 (see attachment: "Fuse Disotoriton"
Some fuses may be there to protect against speaker shorts damaging the amp, and some may be to protect the speakers against a faulty amp burning out the speaker.
If someone really wanted to think about how to solve this problem without affecting the sound they would probably have to look into floating grounds, crowbars and circuit breakers. I believe that this is what Quad did with, for example, their model 306. As always, it is the most mundane bits of engineering that take the most effort.
Experiment I'd say, you and you only knows best what you are hearing.
Enjoying the recent legalization and regulation in Canada?
